200520
200520
    DESCO
    DESCO EUROPE / VERMASON - 200520 - Antistatic Bag, Shielding (Metal-In), Resealable, 203.2mm W x 254...
200520 数据手册
Overall Width (OW) Lip Opening A. Electrostatic bubble shielding bags are made of metalised film, laminated to antistatic pink bubble film. B. This material offers excellent ESD protection combining the ‘Faraday Cage’ effect with an air gap. It also offers good mechanical protection and, being partially transparent, permits easy identification of contents. Its heavy-duty construction makes it suitable for re-use. C. The bags have a flap to enclose contents. Specifications: Meets EN 61340-5-1 and Packaging standard EN 61340-5-3 Electrical Properties Surface Resistance:   Outer Layer   Inner Layer Static Decay Discharge Shielding Charge Generation Physical Properties Thickness:   Polyester   Antistatic PE Bubble properties   Diameter   Height Tensile strength Puncture resistance Transparency MVTR Length (L) Weld Seal Width (W) Typical Values 1 x 104 to < 1 x 1011 ohms 1 x 104 to < 1 x 1011 ohms 25lbs >15%
200520 价格&库存
很抱歉,暂时无法提供与“200520”相匹配的价格&库存,您可以联系我们找货
