231250
231250
    DESCO
    DESCO EUROPE / VERMASON - 231250 - Earth Bonding Point, 10mm Stud, 1Mohm Resistor, 4m Lead
231250 数据手册
Description VER - 26473 This is a straight grounding cord, with either a 10mm male snap stud or 10mm female snap socket and two 4mm banana jacks in the molded head. The banana jacks provide grounding for two wrist straps. The other end of the grounding cord is terminated by a 5mm ring terminal, a 4mm plug or a 10mm socket. A common ground point or earth bonding point (EBP) ties together several elements of an EPA such as bench working surface, floor mat or wrist strap. In this manner, all are kept at the same electrical potential. Note: Cord does not include a current limiting resistor. Specification Conductor: Cord length: Colour: Molded plug end pull force: 7 end tinsel wire 4m Black > 3kg Item Description VER-26473 EBP Cord, 4m, 10mm Stud, 2 x Banana Jacks, M5 Ring Terminal VER-27100 EBP Cord, 4m, 10mm Socket, 2 x Banana Jacks, Banana Plug, Crocodile Clip, 10mm Term Socket VER - 27100 “Common ground point, grounded device or location where the conductors of two or more ESD control items are bonded” [EN 61340-5-1 Edition 1.0 2007-08 clause 3.1] Unless otherwise noted, tolerance is ±10% Special manufactured items are not returnable for credit. Earth Bonding Plug Cord VERMASON UNIT C, 4TH DIMENSION, FOURTH AVENUE, LETCHWORTH, HERTS, SG6 2TD UK PHONE: +44 (0) 1462-672005, FAX: +44 (0) 1462-670440 E-MAIL: Service@Vermason.co.uk, INTERNET: Vermason.co.uk © 2015 VERMASON. Drawing Number VER-26473 DATE: December 2015
231250 价格&库存
很抱歉,暂时无法提供与“231250”相匹配的价格&库存,您可以联系我们找货
