242277
242277
    DESCO
242277 数据手册
Antistatic Cellulose Tape 242276 242272 For general purpose applications • 2.4 mil (0.06 mm) total thickness • Cellulose film resistance 10E10 - 10E11 ohms per IEC 61340-2-3 • Rubber based adhesive absorbs moisture • Adhesive surface resistance 10E10 - 10E11 ohms • Temperature Range -10°C - 71°C (14°F - 160°F); meets MIL-B-81705 of 100°C for 10 min max • Available in clear, clear with ESD symbols, and clear with ESD symbols with yellow stripe. Marking is approved symbols of Mil STD-1285* and CLC / TR 61340-5-2:2008. • Symbols printed in between film and adhesive; will not rub off. Width - See Metric Note Tape is wound on a low-sloughing plastic core. RoHS Compliance Statement None of the following materials are intentionally added in manufacturing this product: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE) as outlined in the Directive 2002/95/EC Article 4.1. See Vermason Inc. letter on-line at Vermason.co.uk/pdf/RoHScompliancy.pdf. Replace regular adhesive tapes with Antistatic tapes complying with EN 61340-5 • “All generators of electrostatic charges, such as untreated plastic films, foams, synthetic fibres, adhesive tapes, etc., must be prohibited and should be kept away from the EPA [ESD protected area].” (EN 61340-5-2 section 6) • “EPA should never have any electrostatic generative adhesive tapes or labels, as these can cause very high potentials when applied or stripped off.” (EN 61340-5-1 section 7.4) Wescorp Tape Storage and Limited Warranty: The user must determine the suitability for use of an antistatic tape for his particular application. For best results, tape inventory should be continually replenished. It is recommended that rolls of tape be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat. Tape over one year old should be evaluated by the user to determine acceptability for the user’s application. Vermason recommends those tracking useful life of product to use shipping/invoice date as Vermason expressly warrants that for a period of one (1) year from the date of purchase, our Wescorp Brand ESD Tape will be free of defects in material (parts) and workmanship (labor). See details of Limited Warranty online at Vermason.co.uk *Wescorp is a Desco Industries brand. Tape 12mm 18mm 24mm 48mm Core Length Antistatic Clear 242270 242271 242272 242273 76.22mm 65.8 m Cellulose with Symbols Antistatic Clear Cellulose 242274 242275 242276 242277 76.22mm 65.8 m w/Symbols & Yellow Stripe Tape widths are nominal metric ±0.8 mm 6 mm 12 mm 18 mm 24 mm 48 mm nominal nominal nominal nominal nominal or or or or or 0.236” 0.472” 0.709” 0.945” 1.890” ±.031 ±.031 ±.031 ±.031 ±.031 Employee Owned Imprint on Clear Cellulose with Symbols Antistatic Tape No sulfur, surfactants or silicone based material (adhesive, film backing, release material) is used in the manufacture of our cellulose tape. Imprint on Clear Cellulose w/ Symbols w/Yellow Stripe *Military organizations sometimes use MIL-STD-1285 for hardware marking and that document once required the use of the “three arrows in a circle” symbol. That symbol has been changed for consistency with industry marking to the “hand in triangle” ESD Susceptibility symbol. (Ref: TR20.20 section 5.3.14.1) Specifications and procedures subject to change without notice. WESCORP* ESD CELLULOSE TAPE, PLASTIC CORE VERMASON UNIT C, 4TH DIMENSION, FOURTH AVENUE, LETCHWORTH, HERTS, SG6 2TD UK Phone: +44 (0) 1462-672005, Fax: +44 (0) 1462-670440 E-MAIL:Service@Vermason.co.uk, internet: Vermason.co.uk © 2010 Desco Industries Inc. Antistatic Tape DRAWING NUMBER 242270 DATE: April 2010
242277 价格&库存
很抱歉,暂时无法提供与“242277”相匹配的价格&库存,您可以联系我们找货
