ESD High Temp Masking Tape
Used in applications masking PCB gold features for wave soldering
Tape is wound on
a paper core.
The user must determine
the suitability for use of the
product for its intended use
Wescorp Tape Storage and Limited Warranty:
The user must determine the suitability for use of an antistatic tape for his particular
application. For best results, tape inventory should be continually replenished. It
is recommended that rolls of tape be stored flat and rotated (flipped over to the
other side) periodically. Tapes should be stored in a dry, well ventilated room with a
reasonably consistent temperature of 68°F (20°C) and be protected from exposure
to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat.
Tape over one year old should be evaluated by the user to determine acceptability for
the user’s application. Vermason recommends those tracking useful life of product to
use shipping/invoice date as Vermason expressly warrants that for a period of one (1)
year from the date of purchase, our Wescorp Brand ESD Tape will be free of defects
in material (parts) and workmanship (labor). See details of Limited Warranty online at
Vermason.co.uk
• Waterproof
• Does tribocharge, but has minimal charge retention
• 7 mil 0.007" (0.18 mm) total thickness
• Adhesive surface 1.2 x 10E11 ohms
• Film resistance < 1 x 10E11 ohms tested per ANSI/ESD S11.11 at
50% RH
• Max Temp 135°C (275°F) 45 minutes max
• Non-toxic
• pH neutral
• Non-corrosive
• Tensile: 3.93 kg/cm
• Adhesion to Steel: 155.04 g/cm2
• Elongation: 8%
• Temperature Range: -36°C to 135°C (-32°F to +275°F)
• Adhesive Mass: Natural Rubber
• Adhesive: Non-Staining
• Excellent Conformability
Note: Waterproof release coating does generate static charges during unrolling. We
recommend slow unwinding, utilizing an Ionizer to neutralize charge.
Width - See Table
Tape
12 mm 18 mm 24 mm 48 mm
*Wescorp is a Desco Industries brand.
Width tolerance ±0.8 mm
Tape widths are nominal
metric ±0.8 mm (±1/32").
2" is 48 mm nominal or 1.890"
RoHS Compliance Statement
None of the following materials are
intentionally added in manufacturing this
product: lead, mercury, cadmium, hexavalent
chromium, polybrominated biphenyls (PBB)
or polybrominated diphenyl ethers (PBDE) as
outlined in the Directive 2002/95/EC Article
4.1. See Vermason letter on-line at
Vermason.co.uk/pdf/RoHScompliancy.pdf.
WESCORP* ESD HIGH TEMP MASKING TAPE, PAPER CORE
VERMASON
UNIT C, 4TH DIMENSION, FOURTH AVENUE, LETCHWORTH,
HERTS, SG6 2TD UK
Phone: +44 (0) 1462-672005, Fax: +44 (0) 1462-670440
E-MAIL:Service@Vermason.co.uk, internet: Vermason.co.uk
© 2010 Desco Industries Inc.
Employee Owned
Length
ESD High Temp Masking 242278 242279 242280 242281 7.62 cm 54.8 m
1/2" is 12 mm nominal or 0.472"
3/4" is 18 mm nominal or 0.709"
1" is 24 mm nominal or 0.945"
Specifications and procedures subject to change without notice.
Core
DRAWING
NUMBER
242278
DATE:
April
2010
很抱歉,暂时无法提供与“242279”相匹配的价格&库存,您可以联系我们找货
