Description:
Desco Europe Rigid Conductive Boxes are marked with the ESD protective
symbol. Boxes can be supplied with or without high density foam for
insertion of component leads or low density foam which acts as a cushioning
material. Meets EN 61340-5-1 and Packaging standard IEC 61340-5-3.
Properties:
Item
Description
241060
Rigid Conductive Box, 35mm x 35mm x 11mm, Empty
241065
Rigid Conductive Box, 35mm x 35mm x 11mm, 6mm HD in Base Only
241045
Rigid Conductive Box, 75mm x 51mm x 14mm, Empty
241050
Rigid Conductive Box, 75mm x 51mm x 14mm, 6mm HD in Base, FX in Lid
241030
Rigid Conductive Box, 90mm x 64mm x 16mm, 6mm HD in Base, FX in Lid
241010
Rigid Conductive Box, 108mm x 83mm x 13mm, Empty
241015
Rigid Conductive Box, 108mm x 83mm x 13mm, 6mm HD in Base, FX in Lid
241005
Rigid Conductive Box, 230mm x 128mm x 20mm, 6mm HD in Base, FX in Lid
241085
Rigid Conductive Box, 230mm x 128mm x 30mm, Empty
241090
Rigid Conductive Box, 230mm x 128mm x 30mm, 6mm HD in Base Only
241095
Rigid Conductive Box, 230mm x 128mm x 40mm, Empty
241100
Rigid Conductive Box, 230mm x 128mm x 40mm, 6mm HD in Base, FX in Lid
All dimensions are internal
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
EUROPE
© 2017 DESCO INDUSTRIES INC.
Employee Owned
Material:
Black conductive polypropylene
Resistance (Rs):
1 x 102 to < 1 x 105 ohms per IEC 61340-2-3
Size Tolerance:
± 0.8mm
Melting Temperature:
80°C to 90°C
Hinge:
Moulded one-piece (241015-241065)
Pin two-piece (241000-241005 and 241085-241100)
Closure:
Snap
Top Foam:
Bottom Foam:
6mm thick low density foam (FX)
6mm thick high density foam (HD)
All boxes have the ESD Protective Symbol moulded into them.
“ESD protective packaging.... when required, shall be defined for all material movement within
protected areas, between protected areas, between job sites, field service operations and to the
customer.” [EN 61340-5-1 Clause 5.3.5 Packaging]
"Conductive materials may be surface conductive, volume conductive or both. A surface
conductive material shall have a surface resistance of
很抱歉,暂时无法提供与“241100”相匹配的价格&库存,您可以联系我们找货
