Tape is wound on a low-sloughing plastic core.
RoHS Compliance Statement
None of the following materials are intentionally added in manufacturing this product: lead,
mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated
diphenyl ethers (PBDE) as outlined in the Directive 2002/95/EC Article 4.1. See Vermason Inc.
letter on-line at Vermason.co.uk/RoHS.aspx.
Replace regular adhesive tapes with ESD tapes complying with EN 61340-5
• “All generators of electrostatic charges, such as untreated plastic films, foams,
synthetic fibres, adhesive tapes, etc., must be prohibited and should be kept
away from the EPA [ESD protected area].” (EN 61340-5-2 section 6)
• “EPA should never have any electrostatic generative adhesive tapes or labels,
as these can cause very high potentials when applied or stripped off.” (EN
61340-5-1 section 7.4)
Wescorp Tape Storage and Limited Warranty:
The user must determine the suitability for use of an ESD tape for his particular application. For
best results, tape inventory should be continually replenished. It is recommended that rolls of tape
be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a
dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected
from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat.
Tape over one year old should be evaluated by the user to determine acceptability for the user’s
application. Vermason recommends those tracking useful life of product to use shipping/invoice
date as Vermason expressly warrants that for a period of one (1) year from the date of purchase,
our Wescorp Brand ESD Tape will be free of defects in material (parts) and workmanship (labor).
See details of Limited Warranty online at Vermason.co.uk
*Wescorp is a Desco Industries brand.
No sulfur, surfactants or silicone based material (adhesive, film backing, release material) is used
in the manufacture of our cellulose tape.
Specifications and procedures subject to change without notice
ESD Cellulose Tape
For general purpose applications
• 2.4 mil (0.06 mm) total thickness
• Cellulose film resistance 10E10 - 10E11ohms
• Rubber based adhesive absorbs moisture
• Adhesive surface resistance 10E10 - 10E11 ohms
• Temperature Range -10°C - 71°C (14°F - 160°F);
meets MIL-B-81705 of 100°C for 10 min max
• Available only in clear.
Tape
12 mm
18 mm
ESD Clear Cellulose
242290
242293
242291 242292
2.54 cm
242296
242294 242295
7.62 cm
24 mm
Core
Length
32.9 m
65.8 m
Width tolerance ±0.8 mm
Tape widths are nominal
metric ±0.8 mm
6 mm
12 mm
18 mm
24 mm
48 mm
nominal
nominal
nominal
nominal
nominal
or
or
or
or
or
0.236"
0.472"
0.709"
0.945"
1.890"
±.031
±.031
±.031
±.031
±.031
Wescorp* ESD Cellulose Tape, Plastic Core
VERMASON
UNIT C, 4TH DIMENSION, FOURTH AVENUE, LETCHWORTH, HERTS,
SG6 2TD UK
PHONE: +44 (0) 1462-672005, FAX: +44 (0) 1462-670440
E-MAIL: Service@Vermason.co.uk, INTERNET: Vermason.co.uk
© 2010 VERMASON.
48 mm
DRAWING NUMBER
242290
DATE:
July
2010
很抱歉,暂时无法提供与“242294”相匹配的价格&库存,您可以联系我们找货
