204075
204075
    DESCO
    DESCO EUROPE / VERMASON - 204075 - Antistatic Bag, Pink, Heat Seal, 254mm W x 355.6mm L
204075 数据手册
A. These products are made of an antistatic polyethylene film that under normal working conditions doesn’t generate triboelectric charges. B. The bags are tough, amine free, do not affect polycarbonate housings and do not cause corrosion. C. The product is transparent and tinted pink. Typical film thickness is 75 micron. D. Bags are hot foil printed in yellow with a descriptive text and ESD protective symbol per EN 61340-5-1. E. Dissipative bags can be used as packaging for ESDS and non-ESD sensitive items in ESD protected areas e.g. passive components, screws. The antistatic properties are long lasting provided the film is stored in a cool dry place. Do not store outside and do not expose the film to heat or store in an overheated warehouse. PHYSICAL PROPERTIES: 920kg/m3 (ASTM D792) Density Thickness Tensile Strength 75 micron MD >10-12mpa (BS 2782) CD >10-12mpa (BS 2782) Elongation MD >250-300% (BS 2782) CD >400-500% (BS 2782) Tear Resistance >50N/mm Thickness (BS 2782) ELECTRICAL PROPERTIES: For product listings, Click Here. Inner Surface Resistance (50% RH) 1 x 105 to < 1 x 1011 ohms (IEC 61340-2-3) Outer Surface Resistance (50% RH) 1 x 105 to < 1 x 1011 ohms (IEC 61340-2-3) Shelf Life 2 years CHEMICAL PROPERTIES: RoHS 3, REACH, and Conflict Minerals Statement See the Desco Europe RoHS 3, REACH, and Conflict Minerals Statement: DescoEurope.com/ROHS.aspx See the Desco Europe Limited Warranty: DescoEurope.com/Limited-Warranty.aspx Antistatic Additive Amine Free - Non-Corrosive and Polycarbonate Compliant RoHS 2 and REACH Compliant MD = Machine direction, CD = Cross direction See the Desco Europe Disclaimer: DescoEurope.com/Disclaimer.aspx “Packaging used within an EPA shall consist of dissipative or conductive materials for intimate contact.” [EN 61340-5-3 Clause 5.2 Inside an EPA] Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. EUROPE © 2017 DESCO INDUSTRIES INC. Employee Owned Made in the United Kingdom Antistatic Pink Bags DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 204020 DATE: December 2017
204075 价格&库存
很抱歉,暂时无法提供与“204075”相匹配的价格&库存,您可以联系我们找货
