Description
Earth grounding points on bench and floor mats are used to
connect ground cords, these must be riveted through the mat
material. The Desco Europe punch and anvil are simple but
effective tools to achieve a neat finish with firm materials, no
thicker than 4mm.
Both tools are mild steel, with a bright zinc and passivate finish
The “10mm-stud-and-post” set creates earth grounding points on
bench and floor mats to which to connect ground cords.
Instructions for use of punch and anvil rivet stud
• Punch a 5mm diameter hole in mat in desired location.
• Insert post from underneath, apply stud over the protruding
post on upper side.
• Fit anvil under the post.
• Place punch inside stud and hammer post until it rolls and a
tight assembly is achieved.
• Alternately, the punch may also be fitted in a hand-operated
arbor press for installation
• Check that the stud holds firmly and makes good electrical
contact with the mat.
Item
230660
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
EUROPE
© 2017 DESCO INDUSTRIES INC.
Employee Owned
Description
Punch and Anvil with 10 Sets of 10mm Studs & Posts
Made in the
United Kingdom
DESCO EUROPE
2A DUNHAMS LANE, LETCHWORTH GARDEN CITY,
HERTFORDSHIRE, SG6 1BE, UK
PHONE: +44 (0) 1462 672005
E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com
Drawing Number
230660
DATE:
December
2017
很抱歉,暂时无法提供与“230660”相匹配的价格&库存,您可以联系我们找货
