Description
Vermason 211045 Disposable ESD Bootie is designed to be worn by personnel grounded via a
Person/footwear / flooring system per EN61340-5-1 Table 2. “For standing operations,
personnel shall be grounded via a wrist strap system or by a flooring/footwear system.” [EN
61340-5-1 clause 5.3.2]. Vermason 211045 Disposable ESD Bootie is to be worn with
grounding tab placed in the person’s shoe under their foot with grounding tab portion at bottom
of the Bootie in contact with ESD flooring. Booties are to be worn on both feet, and while worn
should be tested per IEC 61340-5-1 Clause A.2 using a footwear tester (with lower limit of 50
kilohms and 35 megohms upper limit).
Features and Benefits
• Disposable ESD Bootie Use for Person/footwear / flooring system per EN61340-5-1
• Lightweight “one size fits all” ESD Booties with elastic opening. Comfortable for users; stock
only one item
• Sold 150 pairs per box. Provides outstanding value
• Low sloughing fabric Cleanroom compatible for most applications
• Designed not to scratch or mark flooring. No offsetting maintenance costs
• Product was acquired from ITW Richmond Prior item numbers: BOOTIE and 8454560909
Top
Item
Bottom
Description
211045 Disposable Conductive Booties, Footwear, 0 MEG,150 Pair per Box
Unless specified tolerance ±10%
Note:
“The operator shall stand with one foot on the conductive footwear electrode. The
hand contact plate shall be pressed to verify that the person/footwear system
resistance is within acceptable parameters. The test shall be repeated for the other
foot. The test apparatus can be an integrated, commercially available tester or
other instrumentation that is capable of measuring resistance from 5,0x10E4 ohms
to at least 1,0x10E8 ohms. The tester open-circuit voltage is typically between 9 V
d.c.and 100 V d.c.” [EN 61340-5-1 Edition 1.0 2007-08 Annex A Test method A.2
Measurement procedure for footwear testing]
Tab to Bottom resistance:
Rp-p 5 x 10^4 to 5 x 10^6 ohms tested per IEC 61340-5-1 Clause A.2
Specifications and procedures subject to change without notice.
Vermason
Unit C, 4th Dimension, Fourth Avenue,
Letchworth, Hertfordshire, SG6 2TD, United Kingdom
Phone: +44 (0)1462 672005 Fax: +44 (0)1462 670440
Internet: Vermason.co.uk
©2011 DESCO INDUSTRIES INC.
Employee Owned
DRAWING
NUMBER
211045
DATE:
April
2011
很抱歉,暂时无法提供与“211045”相匹配的价格&库存,您可以联系我们找货
