Designed to be used with a Coiled Cord (included with Wrist Straps)
with a one megohm current limiting resistor meeting the EN 61340-5-1
Personnel Grounding requirements tested per ANSI/ESD S1.1.
Description
229984
229982
No metal to skin contact
Option for those with skin allergies
Widely adjustable, elasticated fabric band
Conductive fibres on the inside
Desco logo moulded into the cap
10 mm stud fitted
Specifications:
RS interior of band: < 1 x 105 ohms Test Method: ANSI/ESD S1.1 (5.2)
RS exterior of band: > 1 x 107 ohms Test Method: ANSI/ESD S1.1 (5.2)
Circumference: adjustable from 120 mm to 200 mm
229980
229987
Item
Description
229978
Adjustable Elastic Wristband Only, 10 mm, Dark Blue
229979
Adjustable Elastic Wristband Only, 10 mm, Dark Blue, Pack of 100
229980
Adjustable Elastic Wristband Only, 10 mm, Light Blue
229981
Adjustable Elastic Wristband Only, 10 mm, Light Blue, Pack of 100
“All personnel shall be grounded or equipotentially bonded according to the requirements
below when handling ESDS. When personnel are seated at ESD protective workstations,
they shall be connected to ground via a wrist strap system. [IEC 61340-5-1 Clause 5.3.3
Personnel grounding]
229982
Adjustable Elastic Wristband Only, 10 mm, Red
229983
Adjustable Elastic Wristband Only, 10 mm, Red, Pack of 100
229984
Adjustable Elastic Wristband Only, 10 mm, Yellow
"A wrist strap system consists of three elements: a person, a ground cord and a wrist
band. To ensure that the resistance to ground of personnel is within the specifications, it
is important to measure the entire system (i.e. from the person’s body to the end of the
ground cord)."
“Wrist straps typically consist of a band which makes contact with the wearer’s skin. The
band is then attached to a ground cord which is connected to the ESD ground.”
“The band is a flexible, form-fitting device designed to make a reliable continuous connection to a person's wrist.”
[IEC TR 61340-5-2 User guide Wrist Strap Clauses 5.3.2.3, 5.3.3.4.2.1, and 5.3.3.4.2.2]
229985
Adjustable Elastic Wristband Only, 10 mm, Yellow, Pack of 100
229987
Wrist Strap, 10 mm, Dark Blue with Yellow Coiled Cord, 2 m long, 10 mm Plug
229988
Wrist Strap, 10 mm, Dark Blue with Yellow Coiled Cord, 2 m long, 10 mm Socket
229989
Wrist Strap, 10 mm, Red with Black Coiled Cord, 2 m long, 10 mm Socket
229990
Wrist Strap, 10 mm, Yellow with Yellow Coilded Cord, 2 m long, 10 mm Socket
Made in the
United Kingdom
See Drawings 230115, 230120 for details on Coiled Cords
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
Adjustable Elastic Wristbands and Wrist Straps, 10 mm
DESCO EUROPE
2A DUNHAMS LANE, LETCHWORTH GARDEN CITY,
HERTFORDSHIRE, SG6 1BE, UK
PHONE: +44 (0) 1462 672005
E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com
© 2021 DESCO INDUSTRIES INC.
Employee Owned
Drawing Number
229978
DATE:
April
2021
