230245
230245
    DESCO
    DESCO EUROPE / VERMASON - 230245 - ESD Grounding Cord, Coiled, Yellow, 2m
230245 数据手册
Description • 2.5mm polyurethane insulation • Conductor is high strength 7-end duplex tinsel for strength and flexibility • 1 megohm resistor built in each socket (unless otherwise specified) • Colours: black or yellow • Dielectric strength: cords withstand 1250 volts DC for at least one minute 230130 “All personnel shall be grounded or equipotentially bonded according to the requirements below when handling ESDS. When personnel are seated at ESD protective workstations, they shall be connected to ground via a wrist strap system." [EN 61340-5-1 Clause 5.3.3 Personnel grounding] “The ground cord is a wire assembly that connects the wrist band to ground or to a common connection point. It usually consists of an insulated wire with a connector head that attaches to the band on one end and a termination device on the other end for connecting to ground. Ground cords usually contain a current-limiting resistor at the band-connecting end. Any electrical connector that can be attached to ground is acceptable as long as it is mechanically durable. The preferred grounding point for the groundable end of the cord is a point connected to ground or to a common connection point.” [CLC TR 61340-5-2 User guide Clause 4.7.2.2.2 Wrist strap ground cord] Item Description 230130 1m Coiled Cord, 10mm Socket / 10mm Socket, Yellow 230225 2m Coiled Cord, 10mm Socket / 10mm Socket, Black 230240 2m Coiled Cord, 10mm Socket / 10mm Socket, Black, no resistor 230245 2m Coiled Cord, 10mm Socket / 10mm Socket, Yellow 230310 3m Coiled Cord, 10mm Socket / 10mm Socket, Black Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. Made in the United Kingdom Coiled Cords, 10mm Socket, 10mm Socket EUROPE © 2018 DESCO INDUSTRIES INC. Employee Owned DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 230120 DATE: January 2018
230245 价格&库存
很抱歉,暂时无法提供与“230245”相匹配的价格&库存,您可以联系我们找货
