241090
241090
    DESCO
    DESCO EUROPE / VERMASON - 241090 - Antistatic Storage, Conductive, Box, Box, 1.18 ", 30 mm, 9.06 ", ...
241090 数据手册
Description: Desco Europe Rigid Conductive Boxes are marked with the ESD protective symbol. Boxes can be supplied with or without high density foam for insertion of component leads or low density foam which acts as a cushioning material. Meets EN 61340-5-1 and Packaging standard IEC 61340-5-3. Properties: Item Description 241060 Rigid Conductive Box, 35mm x 35mm x 11mm, Empty 241065 Rigid Conductive Box, 35mm x 35mm x 11mm, 6mm HD in Base Only 241045 Rigid Conductive Box, 75mm x 51mm x 14mm, Empty 241050 Rigid Conductive Box, 75mm x 51mm x 14mm, 6mm HD in Base, FX in Lid 241030 Rigid Conductive Box, 90mm x 64mm x 16mm, 6mm HD in Base, FX in Lid 241010 Rigid Conductive Box, 108mm x 83mm x 13mm, Empty 241015 Rigid Conductive Box, 108mm x 83mm x 13mm, 6mm HD in Base, FX in Lid 241005 Rigid Conductive Box, 230mm x 128mm x 20mm, 6mm HD in Base, FX in Lid 241085 Rigid Conductive Box, 230mm x 128mm x 30mm, Empty 241090 Rigid Conductive Box, 230mm x 128mm x 30mm, 6mm HD in Base Only 241095 Rigid Conductive Box, 230mm x 128mm x 40mm, Empty 241100 Rigid Conductive Box, 230mm x 128mm x 40mm, 6mm HD in Base, FX in Lid All dimensions are internal Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. EUROPE © 2017 DESCO INDUSTRIES INC. Employee Owned Material: Black conductive polypropylene Resistance (Rs): 1 x 102 to < 1 x 105 ohms per IEC 61340-2-3 Size Tolerance: ± 0.8mm Melting Temperature: 80°C to 90°C Hinge: Moulded one-piece (241015-241065) Pin two-piece (241000-241005 and 241085-241100) Closure: Snap Top Foam: Bottom Foam: 6mm thick low density foam (FX) 6mm thick high density foam (HD) All boxes have the ESD Protective Symbol moulded into them. “ESD protective packaging.... when required, shall be defined for all material movement within protected areas, between protected areas, between job sites, field service operations and to the customer.” [EN 61340-5-1 Clause 5.3.5 Packaging] "Conductive materials may be surface conductive, volume conductive or both. A surface conductive material shall have a surface resistance of
241090 价格&库存
很抱歉,暂时无法提供与“241090”相匹配的价格&库存,您可以联系我们找货
