242274
242274
    DESCO
242274 数据手册
Specifications Standard Document Meets Requirements of: EN 61340-5-3 Electrical Properties Surface resistance: Packaging Typical Values 1 x 109 to < 1 x 1011 ohms Test Procedures/Method ANSI/ESD STM11.11 Physical Properties Antistatic Tape Antistatic Tape Imprint on Clear Cellulose with Symbols Imprint on Clear Cellulose w/ Symbols w/Yellow Stripe RoHS 2, REACH, and Conflict Minerals Statement See the Desco Europe RoHS 2, REACH, and Conflict Minerals Statement: DescoEurope.com/ROHS.aspx See the Desco Europe Limited Warranty: DescoEurope.com/Limited-Warranty.aspx See the Desco Europe Disclaimer: DescoEurope.com/Disclaimer.aspx No sulfur, surfactants, amines, or silicone based material (adhesive, film backing, release material) is used in the manufacture of our cellulose tape. Wescorp Tape Storage and Limited Warranty: The user must determine the suitability for use of an antistatic tape for his particular application. For best results, tape inventory should be continually replenished. It is recommended that rolls of tape be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat. Tape over one year old should be evaluated by the user to determine acceptability for the user’s application. Desco Europe recommends those tracking useful life of product to use shipping/invoice date as Desco Europe expressly warrants that for a period of one (1) year from the date of purchase, our Wescorp Brand ESD Tape will be free of defects in material (parts) and workmanship (labour). See details of Limited Warranty online at DescoEurope.com *Wescorp is a Desco Industries brand. Note: Tape rolls may vary slightly in colour. Construction: Thickness: Colour:* Temperature Range: Cellulose film tape coated with a high tack, non-staining, rubber adhesive system on plastic core 1.9 mil (0.0019” or 0.06mm) Clear, with ESD symbols -10°C to +71°C (+14°F to +160°F) 100°C for 10 min max Sulfur Content: No Sulfur Backing: Cellulose Adhesive: Synthetic rubber Tensile: 22 LBS./IN Adhesion: 59 OZ/IN Elongation: 22.5% Tape 12mm 18mm 24mm 48mm Core Length ESD clear cellulose 242290 242293 242291 242294 242292 242295 242296 25.4mm 76.2mm 32.9m 65.8m Antistatic clear cellulose with symbols 242270 242271 272272 242273 76.2mm 65.8m Antistatic clear cellulose w/ symbols & yellow stripe 242274 242275 242276 76.2mm 65.8m Width tolerance ±0.8mm *Military organizations sometimes use MIL-STD-1285 for hardware marking and that document once required the use of the “three arrows in a circle” symbol. That symbol has been changed for consistency with industry marking to the “hand in triangle” ESD Susceptibility symbol.“ [ESD TR20.20 section 5.3.14.1] Unless otherwise noted, tolerance ±10%. Specifications and procedures subject to change without notice. Wescorp* ESD Cellulose Tape, Plastic Core DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com © 2018 DESCO INDUSTRIES INC. Employee Owned Tape widths are nominal metric ±0.8mm 6mm nominal or 0.236" ±0.031” 12mm nominal or 0.472" ±0.031” 18mm nominal or 0.709" ±0.031” 24mm nominal or 0.945" ±0.031“ 48mm nominal or 1.890" ±0.031” Drawing Number 242270 DATE: January 2018
242274 价格&库存
很抱歉,暂时无法提供与“242274”相匹配的价格&库存,您可以联系我们找货
