A. Fixed black glass-filled nylon cap with slotted opening to allow size
adjustment.
B. 300 Series Stainless Steel Backplate forms channel to hold up to
10 links of band allowing size adjustment.
C. Snap studs are machined from 300 series stainless steel.
D. 4mm snap stud fits to 4mm spring loaded medical type socket.
E. 10mm snap stud fits to 10mm spring loaded medical type socket.
F. Premium adjustable metal expansion wristband. Inside links are constructed of 300
Series Stainless Steel. Width of links is 16mm.
G. 0.05mm polyphenylsulfone sheet is laminated to each link. Provides >5,000 volt RMS
insulation per ASTM D149. Scratch resistant.
H. Size is adjusted by sliding 1 to 10 links of the band into the backplate “C” channel.
I. 300 Series Stainless Steel clip for electrical contact between snap stud and backplate.
J. Underwriters Laboratory listing 90P1C.
4mm Stud
10mm Stud
Designed to satisfy wrist strap requirements of EN 61340-5-1.
Meets ESD S1.1 cuff resistance interior = 100 kilohms (1 x 102 ohms)
Meets ESD S1.1 cuff resistance exterior = 10 megohms (1 x 107 ohms)
Item
“All personnel shall be grounded or equipotentially bonded according to the requirements
below when handling ESDS. When personnel are seated at ESD protective workstations,
they shall be connected to ground via a wrist strap system."
[EN 61340-5-1 Clause 5.3.3 Personnel grounding]
"A wrist strap system consists of three elements: the person, the wrist cord and a wrist
band. To ensure that the resistance to ground of personnel is within the specifications, it
is important to measure the entire system (i.e. from the person's body to the end of the
ground cord)."
“Wrist straps typically consist of a wrist band which makes contact with the wearer's
skin. The wrist band is then attached to a grounding cord which is connected to the ESD
ground reference.”
“The wrist band is a flexible, form-fitting device designed to make a reliable continuous
connection to a person's wrist."
[CLC TR 61340-5-2 User guide Wrist Strap Clauses 4.5.2, 4.7.2.2, and 4.7.2.2.1]
EUROPE
© 2018 DESCO INDUSTRIES INC.
Employee Owned
Description
Circumference
(fully expanded)
229615 Adjustable Metal Wristband, 4mm Stud
195mm to 245mm
229610 Adjustable Metal Wristband, 4mm Stud, XL
225mm to 280mm
229620 Adjustable Metal Wristband, 10mm Stud
195mm to 245mm
229605 Adjustable Metal Wristband, 10mm Stud, XL
225mm to 280mm
229625 Service Engineer’s Wrist Strap (229620 + 230175) 195mm to 245mm
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
Made in the
United States of America
DESCO EUROPE
2A DUNHAMS LANE, LETCHWORTH GARDEN CITY,
HERTFORDSHIRE, SG6 1BE, UK
PHONE: +44 (0) 1462 672005
E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com
Drawing Number
229615
DATE:
January
2018
很抱歉,暂时无法提供与“229605”相匹配的价格&库存,您可以联系我们找货
