237195
237195
    DESCO
    DESCO EUROPE / VERMASON - 237195 - Antistatic Storage, Rack, 3.66 ", 93 mm, 10.71 ", 272 mm, 8.19 "
237195 数据手册
Meets the resistance required range for packaging of EN 61340-5-1 and Packaging standard IEC 61340-5-3 per IEC 61340-2-3. A. Desco Europe PCB racks are moulded in black conductive polypropylene. B. These racks are a good investment to protect CMOS loaded boards, the design enables the storing of boards approximately 25% longer than their base depth. C. It is recommended that they are used in conjunction with complete static protected work stations. D. Electrical resistance RV: 1 x 103 to < 1 x 105 ohms (test method per IEC 61340-2-3). E. Recommended maximum operating temperature is 75°C Item Description 237195 PCB Rack, 208mm x 272mm x 93mm, slots: 25 x 2mm 237200 PCB Rack, 355mm x 266mm x 128mm, slots: 25 x 3mm “The fundamental ESD control principles that form the basis of IEC 61340-5-1 are as follows: a) Avoid a discharge from any charged, conductive object (personnel, equipment) into the device: This can be accomplished by bonding or electrically connecting all conductors in the environment, including personnel, to a known ground or contrived ground (as on shipboard or on aircraft). This attachment creates an equipotential balance between all items and personnel. Electrostatic protection can be maintained at a pontial different from "zero" voltage ground potential, as long as all items in the system are at the same potential. ..." [EN 61340-5-2 Introduction] Made in the United Kingdom Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. EUROPE © 2017 DESCO INDUSTRIES INC. Employee Owned L-Shaped PCB Racks DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 237195 DATE: December 2017
237195 价格&库存
很抱歉,暂时无法提供与“237195”相匹配的价格&库存,您可以联系我们找货
