A. This Desco Europe PCB rack is moulded from a carbon black-filled
polypropylene compound.
B. These racks are designed to protect CMOS loaded boards in storage.
C. Recommended maximum operating temperature is 85°C.
D. Open carrying handles.
E. Measurements: 175mm x 500mm.
F. Weight: 0.7kg.
G. 20 slots with easy-to-load angle: 3mm x 8mm on a 18.75mm pitch.
H. Recyclable
“Tools intended for use within the EPA [ESD protected area] shall, as far as is
practicable, be so constructed that they do not generate or hold an electrostatic charge
….All tools and machinery, for example electrical, mechanical or pneumatic, shall be
so constructed that any non-insulating part of the tool or machine which may touch an
ESDS [ESD sensitive items] shall be at EPA ground potential.”
[EN 61340-5-1 clause 5.2.10 Tools, machinery, dispensers and test equipment]
Properties
Unit
Test Method
Electrical Properties
Surface Resistance
很抱歉,暂时无法提供与“237215”相匹配的价格&库存,您可以联系我们找货
