238145
238145
    DESCO
    DESCO EUROPE / VERMASON - 238145 - BRUSH
238145 数据手册
238135 238115 238110 Characteristics: • Brushes minimise static charge generation and remove electrostatic charges to ground when held by grounded personnel • Dissipative polypropylene black handles are able to remove charges to ground • Volume Resistance of conductive fibres: 1 x 103 to < 1 x 105 ohms per ANSI/ESD STM11.12 • Volume Resistance of dissipative handle: 1 x 104 to < 1 x 1011 ohms per ANSI/ESD STM11.12 • Two kinds of bristles: soft and hard • Soft bristles are ideal for chemical and electronics applications • Hard bristles are mainly for electronics, especially circuit boards 238125 238130 238100 238145 238105 238155 238150 “Avoid a discharge from any charged, conductive object (personnel and especially automated handling equipment) into the ESDS. This can be accomplished by bonding or electrically connecting all conductors in the environment, including personnel, to a known ground or contrived ground (as on board ship or on aircraft). This attachment creates an equipotential balance between all conducting objects and personnel. Electrostatic protection can be maintained at a potential different from a “zero” voltage ground potential as long as all conductive objects in the system are at the same potential. ” [IEC 61340-5-1 Introduction] Soft bristles are made of conductive yarn and horse hair. Hard bristles are made of conductive yarn, pig hair and horse hair. Generally speaking, once the conductive yarn is added to the bristles, it neutralises the possibility of static build-up caused by the natural hair. Synthetic bristles can easily become charged with static in standard humidity conditions. Natural hair usually builds static in areas of low humidity, but due to the conductive fibres in our brushes, this problem does not take effect. Bristle Bristle Dimensions Hardness Hard 6mm diameter, 17mm (L) Item Style 238100 Round 238105 Round Soft 6mm diameter, 19mm (L) 238110 Flat Hard 16mm (L) x 12mm (W) x 6mm (D) 238115 Flat Hard 18mm (L) x 20mm (W) x 6mm (D) 238125 Flat Hard 20mm (L) x 50mm (W) x 6mm (D) 238150 Block Soft 31mm (L) x 100mm (W) x 3mm (D) 238155 Angled Soft 31mm (L) x 130mm (W) x 3mm (D) 238145 Block Hard 22mm (L) x 75mm (W) x 35mm (D) 238130 Angled Hard 18mm (L) x 35mm (W) x 9mm (D) 238135 Angled Hard 18mm (L) x 60mm (W) x 9mm (D) Made in Israel & the United States of America Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. EUROPE © 2018 DESCO INDUSTRIES INC. Employee Owned Conductive Plastic Brushes DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 238100 DATE: January 2018
238145 价格&库存
很抱歉,暂时无法提供与“238145”相匹配的价格&库存,您可以联系我们找货
