Specifications
Standard Document
Meets Requirements of:
EN 61340-5-3
Electrical Properties
Surface resistance:
Packaging
Typical Values
1 x 109 to < 1 x 1011 ohms
Test Procedures/Method
ANSI/ESD STM11.11
Physical Properties
Antistatic Tape
Antistatic Tape
Imprint on Clear Cellulose
with Symbols
Imprint on Clear Cellulose w/
Symbols w/Yellow Stripe
RoHS 2, REACH, and Conflict Minerals Statement
See the Desco Europe RoHS 2, REACH, and Conflict Minerals Statement:
DescoEurope.com/ROHS.aspx
See the Desco Europe Limited Warranty:
DescoEurope.com/Limited-Warranty.aspx
See the Desco Europe Disclaimer:
DescoEurope.com/Disclaimer.aspx
No sulfur, surfactants, amines, or silicone based material (adhesive, film backing,
release material) is used in the manufacture of our cellulose tape.
Wescorp Tape Storage and Limited Warranty:
The user must determine the suitability for use of an antistatic tape for his particular
application. For best results, tape inventory should be continually replenished. It
is recommended that rolls of tape be stored flat and rotated (flipped over to the
other side) periodically. Tapes should be stored in a dry, well ventilated room with a
reasonably consistent temperature of 68°F (20°C) and be protected from exposure
to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat.
Tape over one year old should be evaluated by the user to determine acceptability for
the user’s application. Desco Europe recommends those tracking useful life of product
to use shipping/invoice date as Desco Europe expressly warrants that for a period of
one (1) year from the date of purchase, our Wescorp Brand ESD Tape will be free of
defects in material (parts) and workmanship (labour). See details of Limited Warranty
online at DescoEurope.com
*Wescorp is a Desco Industries brand.
Note: Tape rolls may vary slightly in colour.
Construction:
Thickness:
Colour:*
Temperature Range:
Cellulose film tape coated with a high tack, non-staining, rubber
adhesive system on plastic core
1.9 mil (0.0019” or 0.06mm)
Clear, with ESD symbols
-10°C to +71°C (+14°F to +160°F) 100°C for 10 min max
Sulfur Content:
No Sulfur
Backing: Cellulose
Adhesive:
Synthetic rubber
Tensile:
22 LBS./IN
Adhesion: 59 OZ/IN
Elongation: 22.5%
Tape
12mm
18mm
24mm
48mm
Core
Length
ESD clear cellulose
242290
242293
242291
242294
242292
242295
242296
25.4mm
76.2mm
32.9m
65.8m
Antistatic clear
cellulose with symbols
242270
242271
272272
242273
76.2mm
65.8m
Antistatic clear cellulose
w/ symbols & yellow stripe
242274
242275
242276
76.2mm
65.8m
Width tolerance ±0.8mm
*Military organizations sometimes use MIL-STD-1285 for
hardware marking and that document once required the use
of the “three arrows in a circle” symbol. That symbol has been
changed for consistency with industry marking to the “hand in
triangle” ESD Susceptibility symbol.“
[ESD TR20.20 section 5.3.14.1]
Unless otherwise noted, tolerance ±10%.
Specifications and procedures subject to change without notice.
Wescorp* ESD Cellulose Tape, Plastic Core
DESCO EUROPE
2A DUNHAMS LANE, LETCHWORTH GARDEN CITY,
HERTFORDSHIRE, SG6 1BE, UK
PHONE: +44 (0) 1462 672005
E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com
© 2018 DESCO INDUSTRIES INC.
Employee Owned
Tape widths are nominal
metric ±0.8mm
6mm nominal or 0.236" ±0.031”
12mm nominal or 0.472" ±0.031”
18mm nominal or 0.709" ±0.031”
24mm nominal or 0.945" ±0.031“
48mm nominal or 1.890" ±0.031”
Drawing Number
242270
DATE:
January
2018
很抱歉,暂时无法提供与“242276”相匹配的价格&库存,您可以联系我们找货
