10557
10557
    DESCO
    抗静电清洁剂 地板 2.5 加仑
10557 数据手册
DESCO INDUSTRIES INC TECHNICAL BULLETIN TB-7063 Statguard® ESD Floor Cleaner Application Instructions Made in the United States of America Figure 1. Statguard® ESD Floor Cleaner 1. Push broom the surface to be cleaned. 2. For damp mop, dilute Statguard® ESD Cleaner 10 to 1 (five (5) gallons of clean water to two (2) quarts of cleaner concentrate). For scrub use 15 to 1. 3. Thoroughly mix the cleaner solution before damp mop application. Use a clean, untreated mop to damp mop the area. Wring out excess fluid and do not flood a treated floor with water. For a scrubbing machine use 175 to 350 RPM with red pad. 4. Allow 30 to 60 minutes drying time before walking on the cleaned area. Clean ESD floor using Statguard® ESD Cleaner. Do not damp mop with high alkaline or high residue cleaner. For Statguard® Finish, using harsh detergents can damage a treated floor's ESD properties. Description Physical Properties Statguard ESD Floor Cleaner is formulated to clean floors treated with Statguard® Dissipative Floor Finish and Statguard® Low-VOC Dissipative Floor Finish, as well as ESD floor tiles such as Statguard® ESD Vinyl Tiles. It is formulated with anti-static agents that will rejuvenate and improve the ESD properties of the flooring surface that it is used with without leaving behind residue that can impede dissipative or conductive properties of the flooring material or finish. ® Application Heavy to moderate traffic floors can be cleaned once a week with Statguard® ESD Floor Cleaner. Light traffic floors can be cleaned 2 to 3 times a month or as needed with Statguard® ESD Floor Cleaner. ® Testing a small area for compatibility if Statguard ESD Floor Cleaner has not been used before is recommended. EQUIPMENT NEEDED: • Push broom • Clean and untreated mop • 2 dedicated buckets (Clean bucket and rinse bucket) • Statguard® ESD Floor Cleaner % Solids 2.5% - 4.5% pH 6.5 - 7.5 Color Light blue Ordor None Coverage 20,000 sq.ft./gal. of concentration Freeze/Thaw Stability Passes three cycles Drying Time 30 - 60 min. @ 55% RH Surface Resistivity 1 x 106 to < 1 x 109 ohms per ANSI/ESD STM7.1 and ESD TR53 Storage Statguard® ESD Floor Cleaner does not have a set life span. The chemicals are not known to degrade over time when stored at the proper temperature conditions as stated in the Safety Data Sheet. We also recommend that the product be stored in its original container and be sealed when not in use. DESCO INDUSTRIES INC - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 • Website: DescoIndustries.com TB-7063 Page 1 of 2 January 2020 © 2020 DESCO INDUSTRIES INC Employee Owned RoHS, REACH, and Conflict Minerals Statement See the Desco Industries RoHS, REACH, and Conflict Minerals Statement: DescoIndustries.com/ROHS.aspx Desco Industries Limited Warranty See the Desco Industries Limited Warranty: DescoIndustries.com/Warranty.aspx Statguard® ESD Floor Cleaner is available from these Desco Industries brands: for service and support in North, South and Central America 2.5 Gallons 10557 5.0 Gallons 10558 for service and support in North, South and Central America 2.5 Gallons 46032 5.0 Gallons 46033 for service and support in United Kingdom and Europe 10 Litres 10557 20 Litres 10558 for service and support in Asia 10 Liters 10557 20 Liters 10558 DESCO INDUSTRIES INC - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 • Website: DescoIndustries.com TB-7063 Page 2 of 2 © 2020 DESCO INDUSTRIES INC Employee Owned
10557 价格&库存
很抱歉,暂时无法提供与“10557”相匹配的价格&库存,您可以联系我们找货
