224715
224715
    DESCO
    DESCO EUROPE / VERMASON - 224715 - ESD Tester, AC Outlet Analyzer and Wrist Strap Tester
224715 数据手册
EUROPE  TECHNICAL BULLETIN TB-7509 AC Outlet Analyser and Wrist Strap Tester Installation, Operation and Maintenance Made in the United States of America “Wrist straps should be tested periodically. The frequency of testing, however, is driven by the amount of usage, wear and ESD risk exposure that can occur between tests. For example, what is the quantity of product handled between test periods? Typical test programs recommend that wrist straps that are used daily should be tested daily. However, if the products that are being produced are of such value that a guarantee of a continuous, reliable ground is needed then continuous monitoring should be considered or even required.” [CLC/TR 61340-5-2 user guide wrist strap clause 4.7.2.4.4 test frequency] The AC Outlet Analyser and Wrist Strap Tester is available in the following models: Item Figure 1. Vermason 224713 AC Outlet Analyser and Wrist Strap Tester Input Voltage Plug 224713 220VAC UK 224715 220VAC Europe* *Not compatible with Swiss (type F) electrical receptacles. Contact Customer Service for a custom quotation. Packaging 1 AC Outlet Analyser and Wrist Strap Tester 1 Certificate of Calibration Installation Plug the tester into an AC outlet. The Outlet Pass LED will illuminate green if the outlet’s wiring is correct and the path to earth ground via the equipment grounding conductor (green wire) is intact. The tester will alarm and Outlet Fail LED will illuminate red if either condition is not met. Figure 2. Vermason 224715 AC Outlet Analyser and Wrist Strap Tester Description The Vermason AC Outlet Analyser and Wrist Strap Tester is an easy-to-use, low cost, plug-in tester. It is designed to confirm the proper orientation of hot, neutral and protective earth ground. The product can also be used as a wrist strap tester per IEC 61340-5-1 clause A.1. Operation 1. Fit the wristband snugly onto your wrist and attach the wrist cord to it. 2. Connect your wrist cord to the wrist strap jack located on the face of the tester. 3. Touch and hold the metal test plate on the tester to perform the test. The green Test Pass LED will illuminate if the wrist strap contains adequate current limiting resistance and continuity form their skin to earth ground. Failure is indicated by a non-illuminated Test LED. The tester may also be used to check the sleeve-to-sleeve conductive path integrity of ESD protective garments. DESCO EUROPE - 2A DUNHAMS LANE, LETCHWORTH, HERTFORDSHIRE, SG6 1BE, UK Phone: +44 (0) 1462 672005 • E-mail: Service@DescoEurope.com, Website: DescoEurope.com TB-7509 Page 1 of 2 January 2018 © 2018 DESCO INDUSTRIES INC. Employee Owned Calibration The AC Outlet Analyser and Wrist Strap Tester is calibrated to NIST traceable standards. Calibration may be performed to ensure that the tester is operating within limits. We recommend annual calibration of our testers. TESTING THE WRIST STRAP TESTER A. LOW FAIL Connect a 675 kilohm resistor @ 5% tolerance between the Wrist Strap Test Jack and the Test Plate. The Wrist Strap Test LED will momentarily illuminate then turn off. This test confirms the LOW FAIL point. B. LOW PASS Connect a 825 kilohm resistor @ 5% tolerance between the Wrist Strap Test Jack and the Test Plate. The Wrist Strap Test LED will remain illuminated until the resistor is removed from the Test Plate. This test confirms the LOW PASS point. C. HIGH PASS Connect a 32 megohm resistor @ 5% tolerance between the Wrist Strap Test Jack and the Test Plate. The Wrist Strap Test LED will remain illuminated unitl the resistor is removed from the Test Plate. This test confirms the HIGH PASS point. Specifications Input Voltage 220VAC ±15% Current Drain < 10mA Operator Resistance Limits (nominal) 750 kilohms - 35 megohms Test Voltage, Open Circuit 27VDC (nominal) Long Term Drift < 0.1% / decade Dimensions 5.1cm x 7.6cm x 5.1cm (Item 224713) 5.0cm x 10.1cm x 4.1cm (Item 224715) Operating Temperature 0° to 40°C Limited Warranty, Warranty Exclusions, Limit of Liability and RMA Request Instructions See the Desco Europe Warranty DescoEurope.com/Limited-Warranty.aspx D. HIGH FAIL Connect a 40 megohm resistor @ 5% tolerance between the Wrist Strap Test Jack and the Test Plate. The Wrist Strap Test LED should not illuminate. This test confirms the HIGH FAIL point. TESTING THE AC OUTLET ANALYSER NOTE: The following procedure should only be done by someone familiar with voltage hazards. This procedure will work for 220VAC as long as the neutral and ground are referenced. 220VAC produced with out of phase 110VAC-Ground-110VAC will produce a FAIL result. Isolate the ground plug from the tester by inserting it into a 3 to 2 plug adapter. A. PASS OUTLET Connect a 5 kilohm resistor @ 5% tolerance between the supply ground and tester ground. The PASS LED should remain illuminated until the resistor is removed. This test confirms the PASS point for the neutral-to-ground resistance. B. FAIL OUTLET Connect a 12.5 kilohm resistor @ 5% tolerance between the supply ground and tester ground. The FAIL LED should remain illuminated until the resistor is removed. This test confirms the FAIL point for the neutral-to-ground resistance. DESCO EUROPE - 2A DUNHAMS LANE, LETCHWORTH, HERTFORDSHIRE, SG6 1BE, UK Phone: +44 (0) 1462 672005 • E-mail: Service@DescoEurope.com, Website: DescoEurope.com TB-7509 Page 2 of 2 © 2018 DESCO INDUSTRIES INC. Employee Owned
224715 价格&库存
很抱歉,暂时无法提供与“224715”相匹配的价格&库存,您可以联系我们找货
