CWI 48
CWI 48
    DESCO
    DESCO EUROPE (FORMERLY VERMASON) - CWI 48 - WRISTBAND SET, BLUE, 10MM
CWI 48 数据手册
D. E. F. ® G. A. B. C. Insulating cap, ABS plastic. Jewel® logo molded into cap. 300 series stainless steel backplate (0.406mm thick). Manufacturing date code is stamped into stainless steel backplate. Small cam lock, allows material replacement. 300 series stainless steel. H. I. DESCRIPTION Band, sapphire clasp Band, ruby clasp Band, amethyst clasp Band, topaz clasp Band, emerald clasp Sapphire clasp only Ruby clasp only Topaz clasp only Emerald clasp only Amethyst clasp only Elastic replacement strip 4mm 60000 60002 60004 60006 60008 60010 60012 60014 60016 60018 10mm 60001 60003 60020 60007 60009 60011 60013 60015 60017 60019 Large cam lock, allows size adjustment, maintains electrical continuity even when open. 300 series stainless steel. Floating cam lock* allows wide opening for easy adjustment and secures material down against base plate when closed. 4mm snap stud machined from 300 series stainless steel. Fits to 4mm spring loaded medical type socket. Coil cord disengages from snap with .45Kg 2.27Kg of perpendicular force. Durable, providing long life well beyond that of sheet metal snaps. Knit elastic band material of light blue fiber; 22mm wide and 2.5mm thick. 50 strands of textured polyester, 36 strands of lycra spandex and 14 strands of silver plated Nylon 6 yarn. Outer surface of light blue fibers act as an insulator. The conductive silver plated Nylon 6 (see G) represents 13.5% of the material by weight. The 14 strands of conductive Nylon are randomly knit on the inner surface of the material and are electrically isolated from the outer surface (grey side). Underwriters Laboratory listing 90P1C. Designed to satisfy wrist strap requirements of IEC 61340-5. Circumference: Min: 63.5mm Max: 330mm Width: 22mm Jewel® Lifetime Limited Warranty Charleswater expressly warrants that for a period of 1 year from the date of purchase, Charleswater Jewel® Wrist Straps and Coil Cords will be free of defects in material (parts) and workmanship (labor). In addition, normal use will not cause Coil Cord resistor strain relief connection or Wrist Band 4 mm snap stud to wear sufficiently to open path-to-ground circuit. Within the lifetime warranty period, a credit for purchase of replacement Charleswater Jewel® products, or, at Charleswater’s option, the Charleswater Jewel® product will be repaired or replaced free of charge. If product credit is issued, the amount will be calculated based upon the original invoice purchase price. See drawing 60260 for coil cord specifications. Made in U.S.A. 60005 *U.S. Patent No. 4,662,695 JEWEL® WRISTBAND, ELASTIC, ADJUSTABLE CONDUCTIVE PRODUCTS LTD. UNIT 17. MILLBROOK BUSINESS PARK, SYBRON WAY CROWBOROUGH, EAST SUSSEX TN6 3JZ UNITED KINGDOM PHONE: 00 44 (0) 1892-665313, FAX: 00 44 (0) 1892-668838 INTERNET: www.charleswater.co.uk © 2003 CHARLESWATER LTD. Drawing Number DATE: 60000.E 06/03 PATENTED* MACHINED CONTOUR SPRING SUPPORT ® A. Barrel type banana plug with machined contour spring support*. Crimped uniformly from 4 sides for maximum strength. Fits industry standard banana jack ≥ 3.99mm. B. Thermoplastic elastomer strain relief molded on. Flex life average >27,500,000 cycles (ESD S1.1). Break load average 13.5 Kg. C. Rapid retraction coil cord compresses length with resulting benefit of less tangling and dragging along work surface. Break load average 13.5 Kg. Various colored polyurethane wire insulation. D. Single T-2940 tinsel conductor. Consisting of 7 strands of polyester wrapped with copper. High flex life. Equivalent is 29 gauge (cir mil and/or Ohms). E. Autosplice brass crimp secures conductors to resistor lead and provides stress relief for resistor. F. One megohm ±5%, 1/4 watt, series resistor limits current for operator safety. G. Spring loaded 4mm medical snap socket. Spring separation 3.18 mm - 4.19 mm". Provides .45 Kg 2.27 Kg breakaway from 4.06 mm snap stud (ESD S1.1). Compatible with most major brands. H. Jewel® logo moulded in compliance with ESD S1.1. I. Date coded with date of manufacture. Designed to satisfy wrist cord requirements of IEC 61340-5. Jewel® Lifetime Limited Warranty Charleswater expressly warrants that, for a period of 1 year from the date of purchase, Charleswater Jewel® Wrist Straps and Coil Cords will be free of defects in material (parts) and workmanship (labor). In addition, normal use will not cause Coil Cord resistor strain relief connection or Wrist Band 4 mm snap stud to wear sufficiently to open path-to-ground circuit. Within the lifetime warranty period, a credit for purchase of replacement Charleswater Jewel® products, or, at Charleswater's option, the Charleswater Jewel® product will be repaired or replaced free of charge. If product credit is issued, the amount will be calculated based upon the original invoice purchase price. Colour Sapphire Ruby Topaz Emerald Amethyst Termination Length* Resistor Banana Banana Banana Banana Banana 1.8m 1.8m 1.8m 1.8m 1.8m 1 1 1 1 1 x x x x x SOCKET SIZE 4mm 10mm 60260 60262 60264 60266 60268 1 1 1 1 1 60261 60263 60265 60267 60269 See drawing 60000 for wristband specifications. *U.S. Patent 5951337 JEWEL® GROUND CORD, WRIST STRAP, RAPID RETRACTION, COILED CHARLESWATER LTD. UNIT 17. MILLBROOK BUSINESS PARK, SYBRON WAY CROWBOROUGH, EAST SUSSEX TN6 3JZ UNITED KINGDOM PHONE: 00 44 (0) 1892-665313, FAX: 00 44 (0) 1892-668838 INTERNET: www.charleswater.co.uk © 2003 CHARLESWATER LTD. Drawing Number DATE: 60260.E 06/03
CWI 48 价格&库存
很抱歉,暂时无法提供与“CWI 48”相匹配的价格&库存,您可以联系我们找货
