Description
• 2.5mm polyurethane insulation
• Conductor is high strength 7-end duplex tinsel for strength and flexibility
• 1 megohm resistor built in each socket (unless otherwise specified)
• Colours: black or yellow
• Dielectric strength: cords withstand 1250 volts DC for at least one minute
230130
“All personnel shall be grounded or equipotentially bonded according to the requirements
below when handling ESDS. When personnel are seated at ESD protective workstations,
they shall be connected to ground via a wrist strap system."
[EN 61340-5-1 Clause 5.3.3 Personnel grounding]
“The ground cord is a wire assembly that connects the wrist band to ground or to a common connection point. It usually consists of an insulated wire with a connector head that
attaches to the band on one end and a termination device on the other end for connecting
to ground. Ground cords usually contain a current-limiting resistor at the band-connecting
end. Any electrical connector that can be attached to ground is acceptable as long as it is
mechanically durable. The preferred grounding point for the groundable end of the cord is
a point connected to ground or to a common connection point.”
[CLC TR 61340-5-2 User guide Clause 4.7.2.2.2 Wrist strap ground cord]
Item
Description
230130
1m Coiled Cord, 10mm Socket / 10mm Socket, Yellow
230225
2m Coiled Cord, 10mm Socket / 10mm Socket, Black
230240
2m Coiled Cord, 10mm Socket / 10mm Socket, Black, no resistor
230245
2m Coiled Cord, 10mm Socket / 10mm Socket, Yellow
230310
3m Coiled Cord, 10mm Socket / 10mm Socket, Black
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
Made in the
United Kingdom
Coiled Cords, 10mm Socket, 10mm Socket
EUROPE
© 2018 DESCO INDUSTRIES INC.
Employee Owned
DESCO EUROPE
2A DUNHAMS LANE, LETCHWORTH GARDEN CITY,
HERTFORDSHIRE, SG6 1BE, UK
PHONE: +44 (0) 1462 672005
E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com
Drawing Number
230120
DATE:
January
2018
很抱歉,暂时无法提供与“230225”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+181.87859
- 10+168.49487
- 50+152.51271
