230370
230370
    DESCO
    DESCO EUROPE (FORMERLY VERMASON) - 230370 - ESD Grounding Cord, Straight, Black, 1.5m, 1Mohm
230370 数据手册
Description • Ground cord used to connect mats to EBP (Earth Bonding Point) plugs • 1 megohm (1 x 106 ohms) built-in resistor in 10mm socket end • 2.5mm cord diameter • PVC insulation with 7-end duplex tinsel copper conductor 230480 Item Description 230480 0.7m Straight Cord, 10mm Socket / M5 Ring Terminal 230370 1.5m Straight Cord, 10mm Socket / M5 Ring Terminal “The protection of ESDS is accomplished by providing a ground path to bring ESD protective materials and personnel to the same electrical potential. All conductor and dissipative items in the environment, including personnel, shall be bonded or electrically connected to a known ground or common connection point. This connection results in a sharing of charge which equalizes the voltage across all items and personnel and eliminates the changes of an ESD event to ESD sensitive devices.” [CLC/TR 61340-5-2 User guide Grounding/bonding systems Clause 4.4.1 Introduction] “Where an equipotential bonding system is used, it is important to verify that the common connection point is sufficiently conductive. The resistance of the common connection point between any two ESD control items should be less than 1 Ω when measured using a DC ohmmeter capable of measuring resistance from 0,1 1 Ω through 1x106 1 Ω with a minimum open circuit voltage of 1,5 V.” [CLC/TR 61340-5-2 User guide Grounding/bonding systems Clause 4.4.4.3 Equipotential bonding] EUROPE © 2018 DESCO INDUSTRIES INC. Employee Owned Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. Made in the United Kingdom Straight Cord, 10mm Socket, M5 Ring Terminal DESCO EUROPE 2A DUNHAMS LANE, LETCHWORTH GARDEN CITY, HERTFORDSHIRE, SG6 1BE, UK PHONE: +44 (0) 1462 672005 E-MAIL: Service@DescoEurope.com, INTERNET: DescoEurope.com Drawing Number 230480 DATE: February 2018
230370 价格&库存
很抱歉,暂时无法提供与“230370”相匹配的价格&库存,您可以联系我们找货
