A. Desco Europe Rigid Dissipative Document Wallets are designed for use within ESD Protected
Areas. Unprotected documents could hold electrostatic charges that may cause damage to ESD
sensitive devices (ESDS).
B. The wallets are made of clear vinyl film that is low-charging, which means that during normal use
they are non-tribocharging.
C. The products contain dissipative additives that bloom to the surface of the film. Being dissipative,
electrostatic charges will be removed when grounded – meets EN 61340-5-1 and EN 61340-5-3.
D. With 4-hole spine.
Film Properties
Property
Nominal Value
Density
1.3g/ccm
Cold break temperature
-20ºC
Heat deflection temperature
+70ºC
Film thickness
200 micron (0.008”)
Film thickness tolerance
± 10%
Outgassing 180ºC,
很抱歉,暂时无法提供与“238780”相匹配的价格&库存,您可以联系我们找货
