Description:
Vermason Rigid Conductive Boxes are marked with the ESD protective symbol.
Boxes can be supplied with or without high density foam for insertion of component
leads or low density foam which acts as a cushioning material. Meets EN 61340-5-1
and Packaging standard IEC 61340-5-3.
Properties:
Item
Description
VER-27022
Conductive Box, 108 x 83 x 13mm, W/6MM HD+FX FOAM
VER-27027
Conductive Box, 230 x 128 x 40mm, W/6MM HD+FX FOAM
VER-27021
Conductive Box, 230 x 128 x 20mm, W/6MM HD+FX FOAM
VER-27026
Conductive Box, 230 x 128 x 30mm, W/6MM HD+FX FOAM
VER-27025
Conductive Box, 35 x 35 x 11mm, W/6MM HD FOAM
VER-27024
Conductive Box, 75 x 51 x 14mm, W/6MM HD + FX FOAM
VER-27023
Conductive Box, 90 x 64 x 19mm, W/6MM HD + FX FOAM
VER-29528
Material:
Black conductive polypropylene
Resistance (Rs):
1 x 102 to < 1 x 105 ohms per IEC 61340-2-3
Size Tolerance:
± 0.8mm
Melting Temperature:
80°C to 90°C
Hinge:
Moulded one-piece (VER-27022,VER-27023,VER-
27024,VER-27025)
Pin two-piece (VER-27021,VER-27026,VER-27027)
Closure:
Snap
Top Foam:
Bottom Foam:
6mm thick low density foam (FX)
6mm thick high density foam (HD)
All boxes have the ESD Protective Symbol moulded into them.
All dimensions are internal
“ESD protective packaging.... when required, shall be defined for all material movement within
protected areas, between protected areas, between job sites, field service operations and to the
customer.”
Per Table 4, conductive packaging required range 1 x 102 to less than 1 x 105 ohms tested per IEC
61340-2-3. [EN 61340-5-1 Edition 1.0 clause 5.3.4 Packaging and Table 4]
Unless otherwise noted, tolerance ±10%
Specifications and procedures subject to change without notice.
Made in the
United Kingdom
VERMASON
UNIT C, 4TH DIMENSION, FOURTH AVENUE,
LETCHWORTH,HERTS, SG6 2TD UK
PHONE: +44 (0) 1462-672005
E-MAIL:Service@Vermason.co.uk, INTERNET: Vermason.co.uk
© 2016 VERMASON
Drawing Number
VER-27022
DATE:
February
2016
很抱歉,暂时无法提供与“241015”相匹配的价格&库存,您可以联系我们找货
