55615602059
55615602059
    VARTA(瓦尔塔)
55615602059 数据手册
Product Information Rechargeable Nickel-Metal-Hydride Button Cells 55615 602 059 2 / V 150 H SK SC PCBD Physical characteristics: Width: Height: Length: Typical weight: Pin Distance (P): Length (L): Pin: 27.0 mm 12.9 +0-1.2mm 15.5 mm 12.4 g 10.0 mm 12.9mm 1.0 mm x 0.25mm Pin out + P L Designation System for Battery Assemblies Connection Insulation 2 / V 150 H SK SC PCBD Configuration Main Applications:  Car and home alarm applications  Medical applications - pipettes  Sensor Network Supply, timer, actor, sensor  Smart grid, metering Quality – Made in Germany  Manufactured on highly automated lines  Direct replacement for Ni-Cd  No memory effect  0% lead, 0% mercury, and 0 % cadmium  All cells have built in safety vent for security in abuse conditions  UL recognition under file BBET2.MH13654  ISO 9000 certified for design and manufacture of rechargeable mass type cells and batteries. Conformity to requirements of ISO 9001  VARTA Microbattery is a leader of Ni-MH Button Cell technology and received several ecological and industry awards  are in line with ROHS (in accordance to EU directive 2002/95/EC). They do not contain the hazardous substances Hg, Cd, Pb, Cr6+, PBBs, PBDEs, as in ROHS, with Cd 1000 ppm *See cell datasheet for further details Cell type Key features:  Good recovery characteristics after long storage period and deep discharge  Sealed rechargeable Ni-MH Button Cells from VARTA Microbattery can be operated in any position  The cells complete the manufacturing process in a charged state  Because of time and temperature depending self- discharge, the state of charge upon receipt can not be precisely defined. Before use, therefore, sealed Ni-MH cells should be recharged. Electrical characteristics*: Nominal Voltage: 2.4 V Typical Capacity: 150 mAh Maximum Discharge current: 280 mA cont. Number of cells System highlights of Ni-MH Button Cells – Robust Family – from VARTA Microbattery:  Excellent overcharge capability due to patented GCE-Electrode  Low self-discharge of 20% at RT after 1 year  Flat and stable discharge voltage  Long life – typical 500 full cycles  Slim design  Wide temperature range - Storage: -40˚C up to +65˚C - Discharge: -20˚C up to +65˚C - Charge 0˚C up to +65˚C Page 1 / 2 www.varta-microbattery.com Rechargeable Nickel-Metal-Hydride Button Cells 55615 602 059 2 / V 150 H SK SC PCBD Page 2 / 2 PROPER USE AND HANDLING Charging Extended charging outside specified temperature ranges may have an adverse effect on cell life. Also permanent charging exceeding the limits of specified temperature ranges may reduce the battery life. The maximum life is achieved, when charging at an average temperature of +20 to +30˚C. Discharging The specified temperature range is from -20 to +60˚C on discharge. Repeated discharge at the extreme temperatures may affect battery life. In all application do not deep-discharge (< 0.6 V / cell) our Ni-MH cells and batteries. Life Expectancy in Long-term use Batteries are chemical products involving chemical reactions. Hence capacity and voltage will decrease over long time use as well as during long-term storage capacity and voltage will drop. Typically, a battery will last 5 years or 1000 IEC cycles, if used under recommended conditions and not overdischarged or overcharged. However, non-observance of recommended conditions concerning storage, charging, discharging, temperature and other factors during use can lead to shortened life expectancy of products and deterioration of performance. Severe use applications Short term use of Ni-MH batteries outside specified ranges maybe possible. Please consult us, if such a requirement exists. DESIGN INFORMATION  Discharge over temperature at 0.2 CA  Self Discharge All data are related to cell characteristics. VARTA Microbattery GmbH Daimlerstraße 1 73479 Ellwangen / Germany Tel. + 49 79 61 / 921 – 0 email: contact.varta-microbattery.com www.varta-microbattery.com SAFETY GUIDELINES Discharge at various loads charge characteristic 0.03, 0.1, 0.3 CA  Keep out the reach of children. If swallowed, contact a physician at once  Do not incinerate or mutilate, may burst or release toxic materials  Do not short circuit, may cause burns  Do not deep-discharge into reserve  Do not solder on the battery directly (use our tagged versions)  Restrict charging current and time to the recommended value  Observe charging temperature: 0 to +65˚C / +85˚C  Battery compartment should provide sufficient space for battery to expand in a case of abuse  Either battery compartment or battery connector should have a design that makes it impossible to place the battery in reverse polarity  Equipment intended for use by children should have tamper-proof battery compartment  Battery of different electrochemical system, grades, or brands should not be mixed  Battery disposal method should be in accordance with local and state regulations  Please refer to our material safety datasheets as supporting documents
55615602059 价格&库存
很抱歉,暂时无法提供与“55615602059”相匹配的价格&库存,您可以联系我们找货
    库存:144
