4106210591
4106210591
    VARTA(瓦尔塔)
4106210591 数据手册
LR 6 / AA Data Sheet power one Primary Alkaline Manganese Clindrical Type Number Designation IEC System 4106 LR6 Zn-MnO2 (Alkaline) Shelf Life (Coding)* Nominal Voltage [V] Typical Capacity C [mAh] Permissible Temperature Range 5 years 1.5 2600 (discharge with high-resistance) - 10 °C ... 50 °C Weight, approx. [g] Volume [ccm] 23 7.69 Dimensions [mm] min: max: Æ A B C E F G 13.5 49.2 7.0 1.0 14.5 50.5 0.5 5.5 - Typical Capacities (at 20°C) Discharge Type 10S/M,1H/D,7D/W Load 1000 mA Photo Flash End Voltage[V] 1.0 0.9 Cycles [c] 340 480 Capacity [mAh] 950 1320 Energy [mWh] 1210 1650 0.9 0.8 Discharge Type Load End Voltage[V] 1H/D,7D/W 3.9 W Time [h] 6.55 7.45 Capacity [Ah] 1.95 2.15 Energy [Wh] 2.25 2.45 1.0 0.9 Time [h] 17.15 18.85 Personal Cassette Players / Capacity [Ah] 2.14 2.30 Tape Recorders Energy [Wh] 2.68 2.84 Motor / Toy Discharge Type 1H/D,7D/W Discharge Type 4H/D,7D/W Transistor Radios Load 10 W Load 43 W End Voltage[V] End Voltage[V] 1.0 0.9 Time [h] 83.50 92.50 Capacity [Ah] 2.50 2.65 Energy [Wh] 3.25 3.35 * In consideration of typical loss of capacity at storage and application. VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Tel.: (+49) 7961/ 921-0, Telefax: (+49) 7961/921-553 Subject to change without prior notice Date of issue: 2003-07-25
4106210591 价格&库存
很抱歉,暂时无法提供与“4106210591”相匹配的价格&库存,您可以联系我们找货
