24223201001
24223201001
    VARTA(瓦尔塔)
24223201001 数据手册
V 23 GA MF Alkaline Manganese Data Sheet Type Number …………………………… Designation IEC ……………………….. 24223 --- System …………………………….…….. Manganese Dioxide / Zinc / KOH - Electrolyte Nominal Voltage ……………………….. Typical Capacity C ……………….……. Load 20 kOhm, at 20°C down to 8.00 V 12,0 V 50 mAh Weight (approx.) ………………………… 7,92 g Volume …………………………………… 2,3 ccm Coding……………………………………. Date of Manufacturing Year/Month Temperature Ranges Storage …………………………………… Discharge ………………………………… min -10°C -10°C max. 65°C* 65°C* Dimensions min Diameter (A) ...……………………………. 9,70 Height (B) ………………………………… 27,5 Shoulder Diameter (F)…………………… 5,0 Shoulder Height (G)……………………… 0,3 Reverse Shoulder Diameter (C)………… 5,0 Reverse Shoulder Height (E)…………… max. 10,30 28,50 5,8 5,8 0,9 Typical Capacities (at 20°C) Discharge Type Continuous 24h/d,7d/w Current [µA]: Load 20000Ω End Voltage: 8.00 V Time: 100 h Capacity [mAh]: 50 Energy [mWh]: 530 * Contact VARTA if the application is intended to be outside the range of -10°C to +65°C. Information and contents in this data sheet are for reference purpose only. They do not constitute any warranty or representation and are subject to change without notice. For most current information and further details, please contact your VARTA representative. VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Subject to change without prior notice! Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Date of issue: 2020-12-02
24223201001 价格&库存
很抱歉,暂时无法提供与“24223201001”相匹配的价格&库存,您可以联系我们找货
