6117101301
6117101301
    VARTA(瓦尔塔)
6117101301 数据手册
CR AA Lithium Manganese Dioxide Data Sheet Type Number …………………………… Designation IEC ……………………….. System …………………………….…….. 6117 --Li-Manganese dioxide / Organic Electrolyte UL Recognition:………………………… Nominal Voltage ……………………….. Typical Capacity C ……………….……. Load 1.0 kOhm, at 20°C down to 2 V MH 13654 (N) 3V 2000 mAh Weight (approx.) ………………………… 21,5 g Volume …………………………………… 8,5 ccm Coding……………………………………. Date of Manufacturing Quarter/Year Temperature Ranges Storage …………………………………… Discharge ………………………………… min -55°C -30°C max. 75 °C 75°C Dimensions Diameter (A) ...……………………………. Height (B) ………………………………… Shoulder Diameter[E]…………………….. Shoulder Height [C]………………………. min 14,45 49,5 7 0,6 max. 14,75 50,5 Segment ………………………………….. Electronic Main Applications …………………..….. Electronic Typical Capacities (at 20°C) Discharge Type Load Continuous 24h/d,7d/w Current [µA]: 1000 Ω Discharge Type Load Continuous 24h/d,7d/w Current [µA]: 620 Ω End Voltage: 2.0 V Time: 745 h Capacity [mAh]: 2000 Energy [mWh]: 5600 End Voltage: 2.0 V Time: 430 h Capacity [mAh]: 1850 Energy [mWh]: 5000 All Data contained herein is for single cells for battery applications, performance data may vary from single cell data, depending on specific battery configuration VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst notice!Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Subject to change without prior Date of issue: 03-09-24
6117101301 价格&库存
很抱歉,暂时无法提供与“6117101301”相匹配的价格&库存,您可以联系我们找货
  • 1+131.72463
  • 20+126.45523
  • 50+121.18583
库存:306
6117101301
