6127901301
6127901301
    VARTA(瓦尔塔)
6127901301 数据手册
CR ½ AA Lithium Manganese Dioxide Data Sheet Type Number …………………………… Designation IEC ……………………….. System …………………………….…….. 6127 --Li-Manganese dioxide / Organic Electrolyte UL Recognition:………………………… Nominal Voltage ……………………….. Typical Capacity C ……………….……. Load 5.6 kOhm, at 20°C down to 2 V MH13654 (N) 3V 950 mAh Weight (approx.) ………………………… 11,5 g Volume …………………………………… 5 ccm Coding……………………………………. Date of Manufacturing Quater/Year Temperature Ranges Storage …………………………………… Discharge ………………………………… min -55°C -30°C max. 75 °C 75°C Dimensions Diameter (A) ...……………………………. Height (B) ………………………………… Shoulder Diameter[L]…………………….. Shoulder Height [M]………………………. min 14,45 24,9 7 0,6 max. 14,75 25,1 Segment ………………………………….. Electronic Main Applications …………………..….. Electronic Typical Capacities (at 20°C) Discharge Type Load Continuous 24h/d,7d/w 5600 Ω Time: 1860 h Capacity [mAh]: 950 Energy [mWh]: 2700 Continuous 24h/d,7d/w 2000 Ω Time: 670 h Capacity [mAh]: 930 Energy [mWh]: 2600 Continuous 24h/d,7d/w 1000 Ω Time: 335 h Capacity [mAh]: 900 Energy [mWh]: 2400 50 µA Capacity [mAh]: 1000 Constant current End Voltage: 2.0 V All Data contained herein is for single cells For battery applications, performance data may vary from single cell data, depending on specific battery configuration VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Subject to change without prior notice! Date of issue: 2004-12-15
6127901301 价格&库存
很抱歉,暂时无法提供与“6127901301”相匹配的价格&库存,您可以联系我们找货
