6430401501
6430401501
    VARTA(瓦尔塔)
6430401501 数据手册
CR 2430 Lithium Manganese Dioxide Data Sheet Type Number …………………………… Designation IEC ……………………….. System …………………………….…….. 6430 CR 2430 Li-Manganese dioxide / Organic Electrolyte UL Recognition:………………………… Nominal Voltage ……………………….. Typical Capacity C ……………….……. Load 5.6 kOhm, at 20°C down to 2 V MH 13654 (N) 3V 280 mAh Weight (approx.) ………………………… 4 g Volume …………………………………… 1,3 ccm Coding……………………………………. Date of Manufacturing Month/Year Temperature Ranges Storage …………………………………… Discharge ………………………………… min -55°C -20°C min Dimensions Diameter (A) ...……………………………. 24,2 Height (B) ………………………………… 2,7 Shoulder Diameter[E]…………………….. Shoulder Height [C]………………………. max. 70°C 65°C max. 24,5 3,0 Segment ………………………………….. Electronic Main Applications …………………..….. Watch Photo Electronic Typical Capacities (at 20°C) Discharge Type Load Continuous 24h/d,7d/w Current [µA]: 5600 Ω End Voltage: 2.0 V Time: 560 h Capacity [mAh]: 280 Energy [mWh]: 785 All Data contained herein is for single cells For battery applications, performance data may vary from single cell data, depending on specific battery configuration VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Subject to change without prior notice! Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Date of issue: 2004-12-16
6430401501 价格&库存
很抱歉,暂时无法提供与“6430401501”相匹配的价格&库存,您可以联系我们找货
    库存:300
    6430401501
      • 1+44.21716
      • 7+43.11329
      • 13+42.44680
      库存:46
      6430401501
        • 25+19.91647
        • 50+19.47909
        • 100+19.06045
        库存:75
