4122210531
4122210531
    VARTA(瓦尔塔)
4122210531 数据手册
6 LR 61 / 9V Data Sheet power one Primary Alkaline Manganese Cylindrical Type Number Designation IEC System 4122 6LR61 Zn-MnO2 (Alkaline) Shelf Life (Coding)* Nominal Voltage [V] Typical Capacity C [mAh] Permissible Temperature Range 5 years 9 550 (discharge with high-resistance) - 10 °C ... 50 °C Weight, approx. [g] Volume [ccm] 46 20.8 Dimensions [mm] min: max: A D E O P 46.5 12.45 24.5 15.5 48.5 46.4 12.95 26.5 17.5 Typical Capacities (at 20°C) Discharge Type Load End Voltage[V] 30M/D,7D/W 180 W Time [m] 753 840 Capacity [Ah] 0.51 0.55 Energy [Wh] 3.81 4.01 6.0 5.4 Pocket Calculators 5.4 4.8 Discharge Type Load End Voltage[V] 1H/D,7D/W 270 W Time [h] 18.15 19.88 Capacity [Ah] 0.51 0.54 Energy [Wh] 3.82 4.03 6.0 5.4 Toys Discharge Type Load End Voltage[V] 2H/D,7D/W 620 W Time [h] 43.15 46.50 Capacity [Ah] 0.53 0.56 Energy [Wh] 4.12 4.28 Transistor Radios * In consideration of typical loss of capacity at storage and application. VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Tel.: (+49) 7961/ 921-0, Telefax: (+49) 7961/921-553 Subject to change without prior notice Date of issue: 2003-07-25
4122210531 价格&库存
很抱歉,暂时无法提供与“4122210531”相匹配的价格&库存,您可以联系我们找货
