6032401501
6032401501
    VARTA(瓦尔塔)
6032401501 数据手册
CR 2032 Lithium Manganese Dioxide Data Sheet Type Number …………………….……… 6032 Designation IEC ………………..……….. CR 2032 System ……………………………..…….. Li-Manganese dioxide / Organic Electrolyte UL Recognition .………………………… MH 13654 (N) Nominal Voltage .……………………….. 3 V Typical Capacity C .……………….……. 230 mAh Load 5.6 kOhm, at 20°C down to 2 V Weight (approx.) ………………………… 3 g Volume ……………….…………………… 0,95 ccm Coding………………….…………………. Date of Manufacturing Month / Year Temperature Ranges min. Storage ………………….………………… - 55°C Discharge ……………….………………… - 20°C max. 70°C 70°C Dimensions Diameter (A) ...……………………………. Height (B) .………………………………… Shoulder Diameter (E) .………………….. max. 20,0 3,2 min. 19,7 2,9 16,0 Segment ………………………………….. Electronic Main Applications …………………..….. Watch Photo Electronic Typical Capacities (at 20°C) Continuous 24h / d, 7d / w Current [µA]: Date of Issue: 2013-05-27 Subject to change without prior notice! Load 5600 Ω End Voltage: 2.0 V Time: 460 h Capacity [mAh]: 230 Energy [mWh]: 645 VARTA Microbattery GmbH Daimlerstraße 1, 73479 Ellwangen, Germany Tel.: +49 79 61 921 - 0 Telefax: +49 79 61 921 - 553 Fo_171 Discharge Type
6032401501 价格&库存
很抱歉,暂时无法提供与“6032401501”相匹配的价格&库存,您可以联系我们找货
    库存:17600
