56650 764 099
56650 764 099
    VARTA(瓦尔塔)
    Lithium Battery 25.6V 22.8Ah Rechargeable
56650 764 099 数据手册
Easy Block 24 Preliminary - Specifications subject to change. 25.6 V | 22.8 Ah nominal | 583 Wh | VKB: 56650 764 099 196,15 mm GENERAL (Battery with safety circuit and plastic) 25 5,2 mm 2 0, 17 Size (l x w x h) in mm 255,2 x 170,2 x 196,15 General Li-Iron-Phosphate Communications CAN Bus (CanOpen) Weight Approx. 7.5 kg m m * Illustration only ELECTRICAL SPECIFICATION Power connection Negative terminal: M6 (six) screw type, rated female terminal Positive terminal: M8 (eight) screw type, rated female terminal CAN BUS connection Type: 2x (two) M12-5, plug, female sockets Mating style: screw thread Coding: A Model: Tyco Electronics T4111002051-000 or similar Nominal voltage 25.6 V Nominal capacity (0.2 C; 2.0 V discharge) 22.8 Ah Nominal energy 583 Wh Charging method Constant current + constant voltage Max. charge voltage 29.2 V (not for cycle life) Rec. charge voltage 28.8 V Max. charge current 22.8 A (not for cycle life) Rec. charge current 20 A Rec. charge cut off Current < 1.2 A Rec. discharge cut off 20 V Max. continuous discharge current 60 A (not for cycle life) Rec. discharge current 20 A Exp. cycle life at (0.9 C / 0.9 C), 22 °C ± 2 °C ≥ 80 % of initial capacity at 4.000 cycles CELL & BATTERY PROTECTION Safety function Over/under temperature, over/under voltage, over current short circuit Fuse 100 A (one time) ENVIRONMENTAL CONDITIONS Charge 0 °C to +50 °C Discharge -20 °C to +60 °C Storage 1 to 3 months at -20 °C to +45 °C 25 to 85 RH % IP rating Not water resistant SAFETY CERTIFICATIONS Please follow VARTA handling and safety precautions for LiIon & LiPolymer. The cell used is a UL recognized component according to UL1642. This battery meets the requirements of battery directives and the battery parts are RoHS-compliant. This battery is certified to according to IEC62133-2:2017 and UN38.3. FEATURES Extra-long cycle life for heavy duty cycle projects and reduced total cost of ownership. Easily connected up to 25 modules in parallel for higher capacities. VARTA Storage GmbH - Rev No. 1 0320 1 year at -20 °C to +24 °C Humidity Housing with locking feature for easy attachment to adjacent module. No external battery management needed. Automatic master-slave status established. Limited 2 year warranty. Minimum order quantity: 250 pcs / Order multiples: 50 pcs - Product for OEM customers only. Distributor MOQs may vary. LITE Zero maintenance, zero emissions.
56650 764 099 价格&库存
很抱歉,暂时无法提供与“56650 764 099”相匹配的价格&库存,您可以联系我们找货
