56654 799 097
56654 799 097
    VARTA(瓦尔塔)
    Lithium Battery 51.8V 29Ah Rechargeable
56654 799 097 数据手册
Easy Blade 48 Preliminary - Specifications subject to change. 230 mm 51.8 V | 32 Ah nominal | 1657 Wh | VKB: 56654 799 097 GENERAL (Battery with safety circuit and plastic / metal combination) 33 0m Size (l x w x h) in mm 230 x 330 x 80 General Lithium-Nickel-ManganeseCobalt-Oxide with BMS Communications CAN Bus (CanOpen) Weight Approx. 10 kg m * Illustration only 80 m m ELECTRICAL SPECIFICATION Power connection Negative terminal: M6 (six) screw type, rated female terminal Positive terminal: M8 (eight) screw type, rated female terminal CAN BUS connection Type: 2x (two) M12-5, plug, female sockets Mating style: screw thread Coding: A Model: Tyco Electronics T4111002051-000 or similar Nominal voltage 51.8 V Nominal capacity (0.2 C; 2.50 V discharge) 32 Ah Nominal energy 1.657 Wh Charging method Constant current + constant voltage Max. charge voltage 58.8 V (not for cycle life) Rec. charge voltage 58.1 V Max. charge current 31 A (not for cycle life) Rec. charge current 10.3 A Rec. charge cut off Current < 1.0 A Rec. discharge cut off 42 V Max. continuous discharge current 60 A (not for cycle life) Rec. discharge current 15.5 A Exp. cycle life at (0.3 C / 0.5 C), 22 °C ± 2 °C ≥ 80 % of initial capacity at 1.000 cycles CELL & BATTERY PROTECTION Safety function Over/under temperature, over/under voltage, over current short circuit Fuse 100 A ENVIRONMENTAL CONDITIONS Charge 0 °C to +45 °C Discharge -20 °C to +55 °C Storage 1 to 3 months at -20 °C to +45 °C 25 to 85 RH % IP rating IP30, not water resistant SAFETY CERTIFICATIONS Please follow VARTA handling and safety precautions for LiIon & LiPolymer. The cell used is a UL recognized component according to UL1642. This battery meets the requirements of battery directives and the battery parts are RoHS-compliant. This battery is certified to according to IEC62133-2:2017 and UN38.3. FEATURES Active cooling for improved lifetime. Easily connected up to 25 modules in parallel for higher capacities. VARTA Storage GmbH - Rev No. 1 0320 1 year at -20 °C to +24 °C Humidity Housing with locking feature for easy attachment to adjacent module. No external battery management needed. Automatic master-slave status established. Limited 2 year warranty. Minimum order quantity: 250 pcs / Order multiples: 50 pcs - Product for OEM customers only. Distributor MOQs may vary. LITE Zero maintenance, zero emissions.
56654 799 097 价格&库存
很抱歉,暂时无法提供与“56654 799 097”相匹配的价格&库存,您可以联系我们找货
