20384903501
20384903501
    VARTA(瓦尔塔)
20384903501 数据手册
V 384 MF Silver Oxide / Zinc Data Sheet Type Number …………………………… Designation IEC ……………………….. System …………………………….…….. Nominal Voltage ……………………….. Typical Capacity C ……………….……. Load 13 kOhm, at 20°C down to 1.2 V 20384 SR736SW (SR41) Silver Oxide / Zinc / NaOH - Electrolyte 1,55 V 37 mAh Weight (approx.) ………………………… 0,62 g Volume …………………………………… 0,16 ccm Coding……………………………………. Date of Manufacturing Month/Year Temperature Ranges Storage …………………………………… Discharge ………………………………… min 0°C 0°C min Dimensions 7,55 Diameter (A) ...……………………………. 3,30 Height (B) ………………………………… 3,50 Shoulder Diameter[E]…………………….. 0,08 Shoulder Height [C]………………………. max. 60°C 60°C* max. 7,90 3,60 Typical Capacities (at 20°C) Discharge Type Continuous 24h/d,7d/w Current [µA]: Load 13000  End Voltage: 1.2 V Time: 330 h Capacity [mAh]: 37 Energy [mWh]: 54 * Contact VARTA if the application is intended to be outside the range of 0°C to +60°C. Information and contents in this data sheet are for reference purpose only. They do not constitute any warranty or representation and are subject to change without notice. For most current information and further details, please contact your VARTA representative. VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Subject to change without prior notice! Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Date of issue: 2015-02-16
20384903501 价格&库存
很抱歉,暂时无法提供与“20384903501”相匹配的价格&库存,您可以联系我们找货
    • 1000+18.21068
    库存:5250
    20384903501
      • 5+28.23192
      • 250+27.52169
      • 500+27.10097
      库存:1805
