4103210591
4103210591
    VARTA(瓦尔塔)
4103210591 数据手册
LR 03 / AAA power one Primary Alkaline Manganese Cylindrical Data Sheet Type Number 4103 Designation IEC System LR03 Zn-MnO2 (Alkaline) Shelf Life (Coding)* 7 years Nominal Voltage [V] Typical Capacity C [mAh] Premissible Temperature Range 1.5 1200 (discharge with high-resistance) -10°C…50°C Weight, approx. [g] Volume [ccm] 11 3.8 Dimensions [mm] Typical Capacities (at 20°C) Discharge Type Load End Voltage [V] 0.9 4M/H,8H/D,7D/W 5.1Ω Time [m] 220 Discharge Type Load End Voltage [V] 0.9 1H/D,7D/W 10Ω Time [m] 480 Discharge Type Load End Voltage [V] 0.9 4H/D,7D/W 75Ω Time [h] 72.5 Portable Lighting Tape Recorders Transistor Radios * In consideration of typical loss of capacity at storage and application. VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Subject to change without prior notice! Date of issue 2006-05-10
4103210591 价格&库存
很抱歉,暂时无法提供与“4103210591”相匹配的价格&库存,您可以联系我们找货
