55123201012
55123201012
    VARTA(瓦尔塔)
    VARTA - 55123201012 - Rechargeable Battery, 1.2 V, Nickel Metal Hydride, 1.8 Ah, AA, Raised Positive...
55123201012 数据手册
VH 1800 AA Rechargeable Cylindrical Cells (NiMH) Data Sheet Type Number Designation IEC System 55123 HR 15 / 51 NiMH UL Recognition MH13654 Nominal Voltage Rated Capacity (0.2 C / 1.0 V) 1.2 V 1800 mAh Impedance AC at 1 kHz, fully charged < 26 mOhm Typical Capacity at 0.2 C / 1.00 V 1850 mAh Max Discharge Current (cont. / 1.0 V) 5400 mA Dimensions Diameter (a) Height (b) Cap Diameter (d) Weight, approx 14.5 – 0.7 mm 49.2 – 1.0 mm 6.5 mm 27 g Charge Conditions Standard Charge Fast Charge (charge termination control recommended). Control parameters Trickle Charge (0.05 - 0.1 C) Temperature Range (1 Storage 1 Year 6 Month 1 Month (1) recharge every 6 months Charge Fast Charge Discharge 180 mA / 16 h (tmax) 900 mA to 1800 mA (0.5 to 1 C) -∆U = 0 – 5 mV DT / dt = 0.8 °C / min (0.5 to 0.9 C) 0.8 °C – 1 °C / min (1 C) Temp. cut-off = 45 – 50 °C Timer: 105 % nominal input 90 - 180 mA -20 °C - +25 °C -20 °C - +35 °C -20 °C - +45 °C 0 °C - 45 °C 10 °C - 45 °C -20 °C - 50 °C Date of Issue: 2012-08-17 Subject to change without prior notice ! VARTA Microbattery GmbH Daimlerstraße 1, 73479 Ellwangen, Germany Tel.: +49 79 61 921-0 Telefax: +49 79 61 921-553 Fo_171 All Data contained herein is for single cells For battery applications, performance data may vary from single cell data, depending on specific battery configuration
55123201012 价格&库存
很抱歉,暂时无法提供与“55123201012”相匹配的价格&库存,您可以联系我们找货
