V 200 H
Rechargeable NiMH Button
Data Sheet
1.)
Type Number:
55620
Sytem:
Nickel Metal Hydride/
Nominal Voltage [V]:
1.2
Nominal Capacity C [mAh]:
200
Typical Capacity C [mAh]:
210
KOH Electrolyte
at 40 mA / 1.00 V
Weight, approx. [g]
7
Dimensions [mm]:
min.
max.
Length [l]:
13.9
14.1
Width Facing [w]:
25.4
25.6
7.1
7.4
Height [h]:
UL Recognition:
Coding:
MH 13654 (N)
Manufacturing 5 digit code
(123 = day/4 = year/ 5 = version)
Temperature Ranges [°C]
min.
max.
Storage: less than 30 days
-40
65
Discharge:
-20
65
Charge:
Charging Method:
Normal Charging:
20 mA for 14 – 16 h
Accelerated Charging (20°C):
40 mA for 7- 8 h
Time controlled, voltage control recommended
Fast Charging
N/A
Trickle Charging:
6 mA
Overcharge (20°C):
20 mA continuous
40 mA up to 1 year
Charge Retention [%] at 20°C:
90
Capacity available after 1 month Storage at 20°C
Internal Resistance [Ohm]:
0.8
at charged cells, 20°C, DC: 0.2 CA/2 CA, (IEC 61951-2)
Impedance [Ohm]:
0.14
at charged cells, 20°C, AC: 1kHz, (IEC 61951-2)
Typical Capacities [mAh]:
at 200 mA / 0.90 V
90
Max. Discharge Current (cont.) [mA]:
300
Life Expectancy (typical):
IEC Cycle:
1000 Cycles
Trickle Charge:
up to 6 years (20°C)
Trickle Charge:
up to 3 years (45°C)
Capacities based on normal charging, 20°C
Prior to use read Rechargeable NiMH Button Cell handbook @ www.varta-microbattery.com
Date of Issue: 2016-01-19
Subject to change without prior notice !
VARTA Microbattery GmbH
Daimlerstraße 1, 73479 Ellwangen, Germany
Tel.: +49 79 61 921-0
Telefax: +49 79 61 921-553
Fo_171
1.)
很抱歉,暂时无法提供与“55620303059”相匹配的价格&库存,您可以联系我们找货
