V 600 HR
Rechargeable Ni-MH Button
Data Sheet
Type Number:
55960
Sytem:
Nickel Metal Hydride/
Nominal Voltage [V]:
1.2
KOH Electrolyte
Nominal Capacity C [mAh]:
580
Typical Capacity C [mAh]:
600
at 116 mA / 1.00 V
Weight, approx. [g]
Dimensions [mm]:
14.5
min.
max.
Length [l]:
23.9
24.1
Width Facing [w]:
33.9
34.1
6.3
6.8
Height [h]:
UL Recognition:
MH 13654 (N)
Coding:
Manufacturing 5 digit code
Temperature Ranges [°C]
min.
max.
Storage: less than 30 days
-40
65
Discharge:
-20
65
(123 = day/4 = year/ 5 = version)
Charge:
Charging Method:
Normal Charging:
58 mA for 14 – 16 h
Accelerated Charging (20°C):
175 mA for 4 h
Time controlled, voltage control recommended
Fast Charging (20°C):
580 mA for h *
Trickle Charging:
5.8 mA
Overcharge (20°C):
17.5 mA up to 12 months
58 mA
Charge Retention [%] at 20°C:
up to 6 months
80
Capacity available after 1 month Storage at 20°C
Internal Resistance [Ohm]:
0.1
at charged cells, 20°C, DC: 0.2 CA/2 CA, (IEC 61951-2)
Impedance [Ohm]:
0.015
at charged cells, 20°C, AC: 1kHz, (IEC 61951-2)
Typical Capacities [mAh]:
at 580 mA / 0.9 V
560
at 1.74 A / 0.9 V
520
Max. Discharge Current (cont.) [mA]:
3000
Life Expectancy (typical):
IEC Cycle:
1000 Cycles (IEC 61951-2)
Trickle Charge:
up to 5 years (20°C)
* (-dv=5-10 mV/ cell; dT/ dt=0.7°C/min)
Capacities based on normal charging
VARTA Microbattery GmbH, Daimlerstraße 1, D-73479 Ellwangen/Jagst
Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553
Subject to change without prior notice !
Date of Issue: 2005-08-02
很抱歉,暂时无法提供与“55960303059”相匹配的价格&库存,您可以联系我们找货
