6205210501
6205210501
    VARTA(瓦尔塔)
6205210501 数据手册
CR 123 A Lithium Manganese Dioxide Data Sheet Type Number …………………………… Designation IEC ……………………….. System …………………………….…….. 6205 CR 17345 Li-Manganese dioxide / Organic Electrolyte UL Recognition:………………………… Nominal Voltage ……………………….. Typical Capacity C ……………….……. Load 100 Ohm, at 20°C down to 2 V MH 13654 (N) 3V 1550 mAh Weight (approx.) ………………………… 17 g Volume …………………………………… 7 ccm Coding……………………………………. Date of Manufacturing Month / Year Temperature Ranges Storage …………………………………… Discharge ………………………………… min -20°C -40°C max. 45°C 70°C*) Dimensions Diameter (A) ...……………………………. Height (B) ………………………………… Shoulder Diameter[L]…………………….. Shoulder Height [M]………………………. min 16,4 33,8 6,2 1,18 max. 17,0 34,5 6.4 1,23 Segment ………………………………….. Electronic Main Applications …………………..….. Photo Electronic Devices Typical Capacities (at 20°C) Discharge Type Load Continuous 24h/d,7d/w 100 Ω End Voltage: 2.0 V Capacity [mAh]: 1550 *) Typical temperature range is -20°C to +60°C, contact VARTA if the application is intended to be outside the range of -20°C to +60°C. All Data contained herein is for single cells For battery applications, performance data may vary from single cell data, depending on specific battery configuration VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Subject to change without prior notice! Date of issue: 2010-07-05
6205210501 价格&库存
很抱歉,暂时无法提供与“6205210501”相匹配的价格&库存,您可以联系我们找货
