56456 302 012
56456 302 012
    VARTA(瓦尔塔)
    Rechargeable Lithium Polymer Battery
56456 302 012 数据手册
Product Information 2P/LPP 503562 S PCM WC  VKB 56456 302 012 MM Y R   month two digits   year one digit   week one digit Circuit Diagram 1. GENERAL Battery Pack including safety circuit & wires with connector Cell   LPP 503562 S PCM  Yes NTC   10kΩ ± 1%; B-value 3435K ± 1% ID   None Configuration  2P stack up Weight  appr. 45g 2. ELECTRICAL SPECIFICATION Rated Capacity Nominal Voltage Watt-Hour Rating Charging Method Max. Charge Voltage: Max. Continuous Charge Current: Rec. Charge Cut Off: Max. Continuous Discharge Current: Rec. Discharge Cut Off: Internal Impedance: Expected Cycle Life @ (1.0C/1.0C) @ 23.5°C   2300mAh min., 2400mAh nominal  3.7V  8.9Wh  Constant Current + Constant Voltage  4.2V   1150mA (limited by cell DS)   23mA or timer 3.5h   2000mA (limited by connector)   3V  approx. 90mΩ  500 cycles > 70% CELL PROTECTION Overcharge Detection Overdischarge Detection: Overcurrent Detection   4.3V ± 20mV (0.8 to 1.2sec. delay, resume 4.1V ± 30mV)   2.4V ± 35mV (76.8 to 115.2msec. delay, @ remove loader & charging current)   3.2A to 5.2A (9.6 to 14.4msec. delay @ discharge) Temperature Range • Charge • Discharge • Storage with >80% capacity recovery • Humidity  0 to +45°C  -20 to +60°C  1 year at -20 to +30°C  3 months at -20 to +45°C  1 month at -20 to +60°C   65 ± 20%RH 4. ENVIRONMENTAL AND SAFETY Please follow VARTA Handling and Safety Precautions for LiIon & LiPolymer. The cell used is a UL recognized component according to UL1642 and UN 38.3 certified. The cell is IEC 62133 edition 2 certified. This battery meets the requirements of Battery Directives and the battery parts are RoHS-Compliant. Minimum Order Quantity: 600 pcs / Order Multiples: 120 pcs - Product for OEM customers only! VARTA Storage GmbH - Rev No. 4 0815 715415 1 00 STF 3. AMBIENT CONDITIONS
56456 302 012 价格&库存
很抱歉,暂时无法提供与“56456 302 012”相匹配的价格&库存,您可以联系我们找货
