56455 201 012
56455 201 012
    VARTA(瓦尔塔)
    Rechargeable Lithium Polymer Battery
56455 201 012 数据手册
Product Information 1/LPP 443441 S PCM W  VKB 56455 201 012 MM Y R   month two digits   year one digit   week one digit 1. GENERAL Battery Pack including safety circuit and wires Cell   LPP 443441 S PCM  Yes NTC   None ID   None Configuration  1S Weight  appr. 13g Circuit Diagram 2. ELECTRICAL SPECIFICATION Rated Capacity Nominal Voltage Watt-Hour Rating Charging Method Max. Charge Voltage: Max. Continuous Charge Current: Rec. Charge Cut Off: Max. Continuous Discharge Current: Rec. Discharge Cut Off: Internal Impedance: Expected Cycle Life @ (1C/1C) @ 23 ±5°C  630mAh min., 660mAh nominal  3.7V  2.5Wh  Constant Current + Constant Voltage  4.2V (±50mV)   630mA (limited by cell DS)   6.3mA or timer 2.5h   1260mA (limited by cell DS)   3V  approx. 130mΩ   500 cycles ≥70% CELL PROTECTION Overdischarge Detection: Overcurrent Detection   4.275V ± 25mV (0.7 to 1.3sec. delay, resume 4.275V ± 25mV)   2.30V ± 58mV (14 to 26msec. delay, resume 2.3V ± 58mV)  2.0A to 4.5A (8 to 16msec. delay @ discharge) 3. AMBIENT CONDITIONS Temperature Range • Charge • Discharge • Storage Temperature • Humidity  0 to +45°C  -10 to +60°C  1 year at -20 to + 30°C with >80% capacity recovery   3 months at -20 to 45°C with >80% capacity recovery   1 month at -20 to 60°C with >80% capacity recovery   65 ± 20%RH 4. ENVIRONMENTAL AND SAFETY Please follow VARTA Handling and Safety Precautions for LiIon & LiPolymer. The cell used is a UL recognized component according to UL1642. This battery meets the requirements of Battery Directives and the battery parts are RoHS-Compliant. The battery is certified according to IEC62133 edition 2 and UN 38.3. Minimum Order Quantity: 600 pcs / Order Multiples: 120 pcs - Product for OEM customers only! VARTA Storage GmbH - Rev No. 4 0116 714359 4 04 STF Overcharge Detection
56455 201 012 价格&库存
很抱歉,暂时无法提供与“56455 201 012”相匹配的价格&库存,您可以联系我们找货
