CR 2450
Lithium Manganese Dioxide
Data Sheet
Type Number ……………………………
Designation IEC ………………………..
System …………………………….……..
6450
CR 2450
Li-Manganese dioxide /
Organic Electrolyte
UL Recognition:…………………………
Nominal Voltage ………………………..
Typical Capacity C ……………….…….
Load 5.6 kOhm, at 20°C down to 2 V
MH 13654 (N)
3V
560 mAh
Weight (approx.) ………………………… 6,2 g
Volume …………………………………… 2,3 ccm
Coding……………………………………. Date of Manufacturing
Month/Year
Temperature Ranges
Storage ……………………………………
Discharge …………………………………
min
-55°C
-20°C
min
Dimensions
Diameter (A) ...……………………………. 24,2
Height (B) ………………………………… 4,6
Shoulder Diameter[E]……………………..
Shoulder Height [C]……………………….
max.
70°C
65°C
max.
24,5
5,0
Segment ………………………………….. Electronic
Main Applications …………………..….. Watch
Electronic
Typical Capacities (at 20°C)
Discharge Type
Load
Continuous
24h/d,7d/w
Current [µA]:
5600 Ω
End Voltage:
2.0 V
Time:
1100 h
Capacity [mAh] 560
Energy m[Wh] : 1550
All Data contained herein is for single cells
For battery applications, performance data may vary from single cell data, depending on specific battery configuration
VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst
Subject to change without prior notice!
Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553
Date of issue: 2004-12-16
很抱歉,暂时无法提供与“6450101501”相匹配的价格&库存,您可以联系我们找货
