55608603059
55608603059
    VARTA(瓦尔塔)
55608603059 数据手册
V 80 H Rechargeable NiMH Button Data Sheet 1.) Type Number: 55608 System: Nickel Metal Hydride/ Nominal Voltage [V]: 1.2 KOH Electrolyte Nominal Capacity C [mAh]: 70 Typical Capacity C [mAh]: 80 At 14 mA / 1.00 V Weight, approx. [g] 4 Dimensions [mm]: min. max. 15.4 15.5 5.8 6.0 Diameter [d]: Height [h]: UL Recognition: Coding: MH 13654 (N) Manufacturing 5 digit code (123 = day/4 = year/ 5 = version) Temperature Ranges [°C] min. max. Storage: less than 30 days -40 65 Discharge: -20 65 Charge: 0 65 Charging Method: Normal Charging: 7 mA for 14 – 16 h Accelerated Charging (20°C): 14 mA for 7-8 h Fast Charging: 35 mA for 3 h * Time controlled, voltage control recommended Trickle Charging: 2.1 mA Overcharge (20°C): 7 mA continuous Charge Retention [%] at 20°C: 90 14 mA up to 1 year Capacity available after 1 month Storage at 20°C Internal Resistance [Ohm]: 1.3 at charged cells, 20°C, DC: 0.2 CA/2 CA, (IEC 61951-2) Impedance [Ohm]: 0.22 at charged cells, 20°C, AC: 1kHz, (IEC 61951-2) Typical Capacities [mAh]: at 70 mA / 0.90 V Max. Discharge Current (cont.) [mA]: 53 140 Life Expectancy (typical): IEC Cycle: 1000 Cycles Trickle Charge: up to 6 years (20°C) Trickle Charge: up to 3 years (45°C) * for fully discharged cells, 20 °C Capacities based on normal charging Prior to use read Rechargeable NiMH Button Cell handbook @ www.varta-microbattery.com Date of Issue: 2016-01-19 Subject to change without prior notice ! VARTA Microbattery GmbH Daimlerstraße 1, 73479 Ellwangen, Germany Tel.: +49 79 61 921-0 Telefax: +49 79 61 921-553 Fo_171 1.)
55608603059 价格&库存
很抱歉,暂时无法提供与“55608603059”相匹配的价格&库存,您可以联系我们找货
