6117501301
6117501301
    VARTA(瓦尔塔)
6117501301 数据手册
CR AA Lithium Manganese Dioxide Data Sheet Type Number: ..................................... 6117 Designation IEC: ................................. --- System: ............................................. Li-Manganese dioxide / Organic Electrolyte UL Recognition: .................................. MH 13654 (N) Nominal Voltage [V]: ........................... 3 Typical Capacity C [mAh]: .................... 2000 Load 1.0 kOhm, at 20 °C down to 2.0 V Weight, approx [g]: ............................. 21,5 Volume [ccm]: .................................... 8,5 Coding: .............................................. Date of Manufacturing Quarter/Year Temperature Ranges [°C]: Storage: ................................ Discharge: ............................. min. max. -55 -30 75 75 Dimensions [mm]: min. max. 14,45 49,5 7 0,6 14,75 50,5 Diameter [A]: ......................... Height [B]: ............................. Shoulder Diameter[L]: .............. Shoulder Height [M]: ............... Segment: ........................................... Electronic Main Applications: .............................. Watch Photo Electronic Typical Capacities (at 20° C): Discharge Type: Continuous 24h/d,7d/w Load 1000 Current [µA]: Discharge Type: Continuous 24h/d,7d/w Current [µA]: VARTA Gerätebatterie GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Tel.: (+49) 7961/83-0, Telefax: (+49) 7961/83-553 Load 620 End Voltage: 2.0 V Ω Time: 745 h Capacity [mAh]: 2000 Energy [mWh]: 5600 End Voltage: 2.0 V Ω Time: 430 h Capacity [mAh]: 1850 Energy [mWh]: 5000 Subject to change without prior notice! Date of Issue : 23.08.99
6117501301 价格&库存
很抱歉,暂时无法提供与“6117501301”相匹配的价格&库存,您可以联系我们找货
