6122101501
6122101501
    VARTA(瓦尔塔)
6122101501 数据手册
Data Sheet ULTRA Lithium 6122 System Lithium-Manganese Dioxide Shelf Life (Coding)* 10 years Nominal Voltage [V] Typical Capacity C [mAh] Permissible Temperature Range 9 1150 (discharge with high resistance) -20°C … 50°C Max. continuous discharge current Max. pulse discharge current 600 mA 1000 mA Weight approx. [g] 41 Dimensions [mm] A D E O P min max 46.5 12.45 24.5 15.5 49 46.4 12.95 26.5 17.5 Typical Capacities (at 20°C) Discharge Type Load End Voltage[V] 24H/D,7D/H 10000Ω Time [h] 1S/1H,24H/1D 7.5 1220 620Ω Smoke Detector Load End Voltage[V] 270 Ω Time [h] Load End Voltage[V] 620 Ω Time [h] 5.4 Discharge Type 1H/D,7D/W 36 5.4 Discharge Type 2H/D,7D/W 86 Radio *In consideration of typical loss of capacity at storage and application. VARTA Microbattery GmbH VARTA-Platz 1, 73479 Ellwangen/Germany Subject to change without prior notice Date of issue: 2021-09-23 Phone: (+49) 7961/921 0, Fax: (+49) 7961 921 2553 Data Sheet ULTRA Lithium 6122 Performance Data (Typical) 6122 has a PTC inside for protection in case of short circuit or if load current is too high. E.g. more than 3.5 A for 5 sec. VARTA Microbattery GmbH VARTA-Platz 1, 73479 Ellwangen/Germany Subject to change without prior notice Date of issue: 2021-09-23 Phone: (+49) 7961/921 0, Fax: (+49) 7961 921 2553
6122101501 价格&库存
很抱歉,暂时无法提供与“6122101501”相匹配的价格&库存,您可以联系我们找货
      库存:272
