6215201013
6215201013
    VARTA(瓦尔塔)
6215201013 数据手册
CR 2/3 AH Lithium Manganese Dioxide Data Sheet Type Number …………………………… Designation IEC ……………………….. System …………………………….…….. 6215 CR 17345 Li-Manganese dioxide / Organic Electrolyte UL Recognition:………………………… Nominal Voltage ……………………….. Typical Capacity C ……………….……. Load 200 Ohm, at 20°C down to 2 V MH13654.(N) 3V 1500 mAh Weight (approx.) ………………………… 16 g Volume …………………………………… 7 ccm Coding……………………………………. Date of Manufacturing Quarter / Year Temperature Ranges Storage …………………………………… Discharge ………………………………… min -30°C -20°C max. 65 °C 65°C Dimensions Diameter (A) ...……………………………. Height (B) ………………………………… Shoulder Diameter[L]…………………….. Shoulder Height [M]………………………. min 16 32,4 6,1 1 max. 17 33,9 Segment ………………………………….. Electronic Main Applications …………………..….. Photo Electronic Devices Typical Capacities (at 20°C) Discharge Type Load Continuous 24h/d,7d/w 200 Ω End Voltage: 2.0 V Time: 108 h Capacity [mAh]: 1500 Energy [mWh]: 4190 All Data contained herein is for single cells For battery applications, performance data may vary from single cell data, depending on specific battery configuration VARTA Microbattery GmbH, Daimlerstr. 1, D-73479 Ellwangen/Jagst Subject to change without prior notice! Tel.: (+49) 7961/921-0, Telefax: (+49) 7961/921-553 Date of issue: 2008-06-02
6215201013 价格&库存
很抱歉,暂时无法提供与“6215201013”相匹配的价格&库存,您可以联系我们找货
