55996101501
55996101501
    VARTA(瓦尔塔)
55996101501 数据手册
V 6 HR Rechargeable NiMH Button Data Sheet Type Number: 55996 Sytem: Nickel Metal Hydride/ KOH Electrolyte Nominal Voltage [V]: 1.2 Nominal Capacity C [mAh]: 6 Typical Capacity C [mAh]: 6.2 at 1,2 mA / 1.00 V Weight, approx. [g] Dimensions [mm]: 0.28 min. max. Diameter [d]: 6.7 6.8 Height [h]: 2.1 2.3 UL Recognition: MH 13654 Coding: Manufacturing 5 digit code (123 = day / 4 = year / 5 = version) Temperature Ranges [°C] min. max. Storage: less than 30 days -40 65 Discharge: -20 65 0 65 Charge: Charging Method: Normal Charging: 0.6 mA for 14 - 16 h Accelerated Charging (20°C): 3 mA for 2.5 h Time controlled, voltage control recommended Trickle Charging: Overcharge (20°C): 0.06 mA 0.18 mA continuous 0.6 mA up to 6 months Charge Retention [%] at 20°C: 80 Capacity available after 1 month Storage at 20°C Internal Resistance [Ohm]: 9 at charged cells, 20°C, DC: 0.2 CA / 2 CA, (IEC 61951-2) Impedance [Ohm]: 3 at charged cells, 20°C, AC: 1 kHz, (IEC 61951-2) Typical Capacities [mAh]: at 6 mA / 0.9 V 4 at 12 mA / 0.9 V 3 Max. Discharge Current (cont.) [mA]: 18 Life Expectancy (typical): IEC Cycle: 1000 Cycles (IEC 61951-2) Trickle Charge: up to 5 years (20°C) Date of Issue: 2012-01-24 Subject to change without prior notice ! VARTA Microbattery GmbH Daimlerstraße 1, 73479 Ellwangen, Germany Tel.: +49 79 61 921-0 Telefax: +49 79 61 921-553 Fo_171 Capacities based on normal charging
55996101501 价格&库存
很抱歉,暂时无法提供与“55996101501”相匹配的价格&库存,您可以联系我们找货
