72-14040
72-14040
    TENMA
    Test Lead, 4mm Banana Plug, Shrouded, 4mm Right Angle Banana Plug, Shrouded, 1 kV, 20 A, Yellow
72-14040 数据手册
Straight 4mm Banana Plug to R/A Plug Safety Patchcord – 1mm2 PVC TM Specifications Lead Length Connector Type A Connector Type B Voltage Rating Current Rating Resistance Cable Contact Material Insulator Material Insulator Colour Temperature : 1m / 3.3ft : Straight 4mm Shrouded Banana Plug : Right Angle 4mm Shrouded Banana Plug : CAT III 1000V : 20A : 25mΩ : 1mm2, PVC : Brass and Beryllium Copper, Nickel Plated : Polypropylene : White, Blue, Yellow, Black, Red and Green : -20°C to 80°C Applications General purpose electric and electronic testing, controlling and measuring. Part Number Table Description Insulator Colour Test Lead, Straight 4mm Shrouded Banana Plug to Right Angle Plug, 1mm2 PVC, 1000V, 20A Lead Length Part Number White 72-14036 Blue 72-14038 Yellow Black 1m 72-14040 72-14042 Red 72-14044 Green 72-14046 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 24/10/18 V1.0
72-14040 价格&库存
很抱歉,暂时无法提供与“72-14040”相匹配的价格&库存,您可以联系我们找货
